Magura Slave Piston Seizing
Greetings
Is there anything I can do to stop the slave piston from seizing? Due to the dry weather and dust accumulating near the seals, the piston just doesn't come back when you release the lever. It helps when you lube it with silicone grease but it only lasts about 6 hours of riding, then you have to do it again :S
The brake is running on water which is probably the cause of this problem.
Any ideas?
use car brake cleaner when the pistons are fully out when the lever is pressed.
Will try that out.
Good translation by the way but it wasn't necessary ;)
pull it out with some plyers/molegrips as far as it will go then just lube it with some thick oil/grease
That's what I've been doing so far, unfortunately the grease doesn't last long and causes dirt to accumulate behind the backings.
Might have to try a different kind of grease though I remember Tart writing that the silicone stuff is the best for this purpose.
How about graphite?
Thought you ran DD?
Anyway, WD40 doesn't really have much lubricating properties. Surely you have some motor oil in your garage?
Well we don't even have a garage, just a shed :P
I'm a mechanical noob, but i'll ask my dad to bring some from his work.
And yea I used to run DD, but the magura marta wasn't holding up enough, and I'm too poor to get a hope so I was kinda forced to go hs33.
Still prefer DD though
this happend to me a while ago when i goy my bike really muddy, problem is the dirt thats what makes it stick, just take you brake apart and give it a really good clean in hot soapy water
i re bleed mine to at the same time also with water
can use a track pump to get the piston out so you can clean
