Hs33 Pads For Front Magura
Alex.loves.boys
Hey
I know theres the pads reveiws e.t.c but i want a direct answer..kinda :P
ive got a front magura.
got dead koxx browns at the moment and its ok but has NO bite.
I have a choice between all the coulours of koxx pads.
i have afresh grind on the front.
which would be best for bite and hold?
i was thinking to myself that a brand new set of browns would be loads better then the old batterd ones.. but are the reds good?the yellows?
i think blue and green would be to soft...
any help would be apreicated :)
CHEERs
When you say you have a choice out of all the colours of koxx pads dose that mean you can only buy koxx pads. Tra use's koxx reds dosent he so i imagine the hold would be imense anyway although i cant give you a direct review as ive never had a set.
Ive always found smooth rims work better for bite.
Prehaps try some zoo pads and smooth your grind over on your front wheel.
