shogun_gimp Posted August 30, 2007 Report Share Posted August 30, 2007 (edited) Over the last couple of nights ive tried to sidehop to the front wheel.... Its only a short video and its only 3 crates high..... its to learn but is this the right way?Thanks for the HelpNigel there it is ^^^^^^^^^^^^^^^^ Edited August 30, 2007 by shogun_gimp Quote Link to comment Share on other sites More sharing options...
Ryan Blackwell Posted August 30, 2007 Report Share Posted August 30, 2007 Yeah you got it mate. Quote Link to comment Share on other sites More sharing options...
eskimo Posted August 30, 2007 Report Share Posted August 30, 2007 Yeah it's right but there is real wrong way about it if you made it up there.That tune made me laugh though Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted August 30, 2007 Report Share Posted August 30, 2007 Don't put the front wheel over the pallets - as yo wouldn't be able to do so with a higher wall Quote Link to comment Share on other sites More sharing options...
sUm Posted August 30, 2007 Report Share Posted August 30, 2007 Your technique seems fine. One suggestion I have is to get more parallel to the object you're going up. That is, get your rear wheel closer to it. Right now it looks like you're mainly using the pedal kick to propel you up onto the pallets which is fine, but as someone already mentioned when you go for higher objects you're likely going to start ramming your front wheel into it. Try getting as close to the object as you can while parallel to it and, as the name implies, hop sideways. Keep up the good work! Quote Link to comment Share on other sites More sharing options...
N Roach Posted August 30, 2007 Report Share Posted August 30, 2007 Square up with the object your going onto......Use the kick and body weight to move sideways onto the pallet. Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted August 30, 2007 Report Share Posted August 30, 2007 not really a right and wrong way to be honest, you seem to be ok, i would say o more paralell with the wall or object you are going to side hop Quote Link to comment Share on other sites More sharing options...
pengsmelly Posted August 30, 2007 Report Share Posted August 30, 2007 ye its ok but if you do it the other way it would be even better. and get a little more side on with the pallets. Quote Link to comment Share on other sites More sharing options...
monkeymoped Posted August 30, 2007 Report Share Posted August 30, 2007 :wizard: :wizard: :wizard: :wizard: tis cool but euro techno tune made me laugh Quote Link to comment Share on other sites More sharing options...
JaMmY Posted August 30, 2007 Report Share Posted August 30, 2007 im not really an expert but try not to put your wheel over the pallets as you cant do that on higher walls. Quote Link to comment Share on other sites More sharing options...
matt rushton Posted August 30, 2007 Report Share Posted August 30, 2007 Yeah is good im just raving around me living room now lol.Matt Rushton Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted August 30, 2007 Report Share Posted August 30, 2007 im not really an expert but try not to put your wheel over the pallets as you cant do that on higher walls.Somebody already said that? , lol anyway.. seems pretty good, but in the long run youll probs find it easyer to do sidehops away from your lead foot.Matx Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted August 30, 2007 Report Share Posted August 30, 2007 I made the exact same topic way back when...Click. As long as you're getting onto it sideways, you're doing it fine. Quote Link to comment Share on other sites More sharing options...
shogun_gimp Posted August 31, 2007 Author Report Share Posted August 31, 2007 Thanks For all the Helpive tried getting square to it yet i couldnt do it this way....is it possible to have some videos of you people doing it so i can get the gist of it?Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted August 31, 2007 Report Share Posted August 31, 2007 Don't put the front wheel over the pallets - as yo wouldn't be able to do so with a higher wallYour technique seems fine. One suggestion I have is to get more parallel to the object you're going up. That is, get your rear wheel closer to it. Right now it looks like you're mainly using the pedal kick to propel you up onto the pallets which is fine, but as someone already mentioned when you go for higher objects you're likely going to start ramming your front wheel into it. Try getting as close to the object as you can while parallel to it and, as the name implies, hop sideways. Keep up the good work!both of those Quote Link to comment Share on other sites More sharing options...
Cahill Trials Kid Posted September 2, 2007 Report Share Posted September 2, 2007 Yh thats pretty much it.When riding just try to be abit looser not all stiff and bend your knees alot more it just makes your riding look alot smother and nicer.Keep up the good work.Sam Quote Link to comment Share on other sites More sharing options...
mods Posted September 2, 2007 Report Share Posted September 2, 2007 (edited) i would start practising going the other way ie towards your right, i sidehop to my left and i'm left footed, i find it holds me back. I can side hop to back wheel to the right almost as high as i can side hop to the left. I'm finding it very hard to hop to the right front wheel first though as i have never learnt it. Edited September 2, 2007 by mods Quote Link to comment Share on other sites More sharing options...
shogun_gimp Posted September 2, 2007 Author Report Share Posted September 2, 2007 (edited) Thanks For All The Help!I finally squared up and can now get up about 4-5 crates.......so thanks for the helpNigelEdit--- But how much i try i cant go to the right :angry: Edited September 2, 2007 by shogun_gimp Quote Link to comment Share on other sites More sharing options...
