duane Posted August 26, 2007 Report Share Posted August 26, 2007 Hi, I need to replace my headset due to it getting rusty and then seizing up. I managed to keep it going for a while by using WD40 after each ride to drive out the sweat and any water that might have got in there, but now its to rough to live with. Its an Echo headset, has anyone else had a problem with this headset, if not I am happy to get another one suspect I might have driven water into it while hosing the bike down after a typically sweaty (40 Degrees) ride. Thanks Duane. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted August 26, 2007 Report Share Posted August 26, 2007 Can you not just take it apart and grease it up?Also, don't hose your bike down, because it ruins all your bearings (as you've found out) use a bucket and sponge to clean it.Or just leave it... Quote Link to comment Share on other sites More sharing options...
