How Can I Get My Grinds Harsher?
Muel
I have searched for ages and copied the technique Krisboats used in his video, and I cannot get my grinds harsh enough.
Any tips? I hold the grinder at 90 degrees to the rim and move the grinder as fast and as hard as I can, but it don't make no difference.
I am using a metal grinding disc, I have tried others, such as cutting discs but to no avail, my mates use diamond tipped cutting discs, where can I get one? This appears to be the only thing I can change.
Please help, I am so lost that I am using Tar on my new rim, lots of bite but no hold whatsoever.
Get a hacksaw, and cut slot's into your disc. space them out depdning on how harsh you want the cuts.
Harsher grind is pretty much a dead cert then.
Edited by Jakers
Now that's the sort of thing I hadn't even thought about. Do you want them closer together for a harsher grind? I'll cut maybe 4-6 in it and then I can add more if need be, I'll practice on an old rim as well.
1. high quality grinding disc, preffably brand new
2.hold the grinder at 60 degrees plus
3.lean fairly hard into the grinder as you litterly drag it accross the rim
4.the quicler you drag the grinder the better
as for the diamond disc ,place's like focus ,b&q ,screww fix direct etc should sell the.hope i've helped,steve
Yeah, and see the mess the disk makes of your face/hands when it shatters...
Just use a standard disk and angle the grinder according to how harsh you want it. Then buy some decent pads. And pull the brake lever hard. Oh, and always wear eye protection when using an angle grinder. One shard of hot metal in the eye and you'll find trials a damn sight harder, brakes or no brakes...
Thats your problem right there. The metal grinding discs are softer so they wear at a similar rate to your rim as your grinding it. Which results in the beginning being nice and sharp but the end being duller and shallower. Get a metal cutting disc from wilko's ;) Its like £2 and even trying to do a light grind with them will result in some canyon-like grooves in the rim. When i gave jonny mc a light grind with this new disc from wilko's it was harsh enough to shave pad material off his rockpad blues just by spinning the wheel on the spot. There was pad dust everywhere.
Using one of those, holding at around 80 degrees and pressing down enough so you can atually hear the grinder speed slowing down will give you one of the harshest grinds on the planet. Though be warned, theres a high chance that using this disc with so much weight behind it theres a higher chance of you making a mistake and cutting a slot into your rim ;)
look guys differant sizes of cutter and stuff will make small changes, I usually have a disc that has some sort of thread in it to stop it shattering (duno the type), and the disc itself is fairly soft, a compound of small bit's of grit etc.
Cutting a few v's in it, I personally think that the less you have the harsher your grind will be, and it will space the bigger cut's further apart, if you have LOADS than it'll be hard to control as the disc wont be round, Try first cutting 4 v's at the quaters, and working up from that if need be, I'd say between 4 and 8 v's or bit of material removed from the outside edge would be plenty, has been in my experiance.
Remember to get the wilko's metal cutting disc. Its in a league of its own.
There isn't a Wiko's round here I think, I'll see about getting one online.
What about this beast?
http://cgi.ebay.co.uk/Diamond-Cutting-Disc...1QQcmdZViewItem
I have a feeling it might just eat my rim.
EDIT: I think I'm going to buy this pack, it will give me some options:
http://cgi.ebay.co.uk/3pc-Diamond-Cutting-...1QQcmdZViewItem
Edited by El Muelio
"page is not responding"
I honestly don't know abouta diamond cutting one, mind you i think unless you spend a bit of money on them most "diamond edged" parts aren't much good anyway.
  • 2 weeks later...
