StuartD Posted August 23, 2007 Report Share Posted August 23, 2007 As good as scrap now?I dont think theres any ways of getting that b*****d out, unless anyone knows a way? Not had the bike 1 week and this is my second problem. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted August 23, 2007 Report Share Posted August 23, 2007 (edited) what hub is it? and if your throwing it away, give it to meeeeeeeeeeeEDIT: plyers/molegrips + vice? Edited August 23, 2007 by ash-kennard Quote Link to comment Share on other sites More sharing options...
StuartD Posted August 23, 2007 Author Report Share Posted August 23, 2007 what hub is it? and if your throwing it away, give it to meeeeeeeeeeeId only throw it out if it was no use, so why would you want it And its Onza Pro Quote Link to comment Share on other sites More sharing options...
N.Wood Posted August 23, 2007 Report Share Posted August 23, 2007 Drill it out. Quote Link to comment Share on other sites More sharing options...
Muel Posted August 23, 2007 Report Share Posted August 23, 2007 Is it an Onza hub? They had a problem with the bolts it these hubs, I got mine out no problem.You should be able to chase it round, it looks like there is a fair bit left sticking out. Quote Link to comment Share on other sites More sharing options...
StuartD Posted August 23, 2007 Author Report Share Posted August 23, 2007 Is it an Onza hub? They had a problem with the bolts it these hubs, I got mine out no problem.You should be able to chase it round, it looks like there is a fair bit left sticking out.The bolts are complete shit, both hex's are rounded... what crap is that -.-, so I need new bolts now anyways >.< Quote Link to comment Share on other sites More sharing options...
Muel Posted August 23, 2007 Report Share Posted August 23, 2007 The bolts are complete shit, both hex's are rounded... what crap is that -.-, so I need new bolts now anyways >.<Don't delete the spaces around your emoticons, otherwise it just shows the text.We just chased mine round with a center punch and a hammer until there was enough to get the pliers on the end of the thread. Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted August 23, 2007 Report Share Posted August 23, 2007 it should be loose, because there's no force on it holding it tight, easy to get out.. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted August 23, 2007 Report Share Posted August 23, 2007 hacksaw a line and screwdriver it out?Or chisel it to pieces?Or chisel a line and screwdriver it out Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted August 23, 2007 Report Share Posted August 23, 2007 me real name makes "a mad oyster"....ed: JT's real name makes some good 'uns done that loads of times...you can get it out with a bit of patience- start gentle otherwise you end up much worse off....IE: with nothing at all to grip.if you can drill a small hole through the bolt you can definitely get it out...i'd recommend allen key bits for ratchets (the ones that taper...) Quote Link to comment Share on other sites More sharing options...
531joshua Posted August 23, 2007 Report Share Posted August 23, 2007 Easy out kit, if you have one.Drill a hole down the middle of the bolt, not very far though, only about 10mm if that.Note: this hole musn't be too wide, about 1mm will do, as the bolt your working with is fairly thin.Then get a special tool, which is basically a bolt threaded specificly for the job in hand.Screw it in anti-clockwise untill it locks, then the bolt should start to unscrew.If you have / buy a easy out kit, instructions on it should be enclosed.If not, google should have some basic instructions / guides. Quote Link to comment Share on other sites More sharing options...
Muel Posted August 23, 2007 Report Share Posted August 23, 2007 I drilled a 3mm hole in one and hammer a torx bit into it, it came out easy then, but the torx bit was fooked. Quote Link to comment Share on other sites More sharing options...
StuartD Posted August 23, 2007 Author Report Share Posted August 23, 2007 (edited) Cheers for the replies, after my college course last year talking about tap and how if they snapped inside the material you were tapping you had to throw it out and start again, got me a lil worried, but ill have a good go at this tomorrow, anyone know where I can get replacement bolts? Edited August 23, 2007 by StuartD Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted August 23, 2007 Report Share Posted August 23, 2007 you mean a tap...that's what cuts a thread into a hole..a taper is when something gets wider as you move along it.....you know what i mean..get a hole in it- helps if you can start it off with something like a small grinding bit on a dremel..just to make sure you're drilling down the middle... Quote Link to comment Share on other sites More sharing options...
StuartD Posted August 23, 2007 Author Report Share Posted August 23, 2007 you mean a tap...that's what cuts a thread into a hole..a taper is when something gets wider as you move along it.....you know what i mean..get a hole in it- helps if you can start it off with something like a small grinding bit on a dremel..just to make sure you're drilling down the middle...haha yeh thats it, couldnt quite put my finger on it, Ill give it a go tomorrow see how i get on Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 23, 2007 Report Share Posted August 23, 2007 The bolts in those hubs (Zoot front hub by the looks of it) are pretty heavily threadlocked in as standard, so it will be faaaairly tricky to get out. Failing that, give Supercycles a shout and they should be able to supply a new axle (easily fitted/removed).Adam Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted August 23, 2007 Report Share Posted August 23, 2007 failing all that.disassemble the hub so you only have the axle with the bolt stuck in it put the axle in the vice and saw straight across the top of the axle (only 1 or 2 mm) then use a screwdriver to whap it out Quote Link to comment Share on other sites More sharing options...
scousertrials Posted August 23, 2007 Report Share Posted August 23, 2007 Take it anywhere that can do welding and they can weld a pice of metal on it and unscrew it out like that Quote Link to comment Share on other sites More sharing options...
Guest Posted August 23, 2007 Report Share Posted August 23, 2007 once you have it out get a quick release, thats what i did when my bolts rounded. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted August 23, 2007 Report Share Posted August 23, 2007 Yeah, I was gunna say, just drill it right out not caring about the threads and buy a quick release. Way better for getting it in cars anyway Quote Link to comment Share on other sites More sharing options...
basher Posted August 23, 2007 Report Share Posted August 23, 2007 If you cant get it out by plyers or vice or cuting a groove to use a screwdriver then you could just drill it out and use a quick release. Quote Link to comment Share on other sites More sharing options...
