Diy Maggie Clamps?
rosswaa
Do you mean the evo mounts on a four bolt mount?
I used evo mounts on a four bolt mount for a while becuase i could not afford to get some mounts (mum and dad are well tight)
They do fit they take a while to set up though.
I used a bolt through the top to pull the clamp together and one bolt to stop it moving outwards and it was fine.
If its all you have for now it will be fine my only advice is dont tighten the top one up as tight aswel u would four bolt ones because on mine it pulled the threads out really easy so beware.
do you have any pictures of this?
yeh i am talking about the new evo 2 mounts, is this still possible?
iv got some clamps coming but hate waiting about for this stuff
Edited by rosswaa
This is the best one i can find,
At the top where the black bolt is that where you will bolt it down.
Where the quick release is there is a oval hole straigt through so u can see the threads on the frame mount the a bolt that will fit just inside to stop it moving about.
