ibs_m Posted August 21, 2007 Report Share Posted August 21, 2007 (edited) Ive looked on the site and its not very clear if the Pro2 single speed 36 hole comes with a 6 bolt disc mount?http://www.hopegb.com/mes_r_typ_s_rayonche...icherche_1.htmlIs there anyway to get hold of one?CheersIbs Edited August 21, 2007 by ibs_m Quote Link to comment Share on other sites More sharing options...
N.Wood Posted August 21, 2007 Report Share Posted August 21, 2007 It does. Quote Link to comment Share on other sites More sharing options...
ibs_m Posted August 21, 2007 Author Report Share Posted August 21, 2007 it doesnt say anything in the detail about it???http://www.hopegb.com/voir_rhpr36btr.htmlHow can you be sure? Quote Link to comment Share on other sites More sharing options...
Orgun_Donor Posted August 21, 2007 Report Share Posted August 21, 2007 (edited) http://www.chainreactioncycles.com/Models.aspx?ModelID=11034also another examplehttp://www.tartybikes.co.uk/product.php?id=371 Edited August 21, 2007 by Orgun_Donor Quote Link to comment Share on other sites More sharing options...
Waddy Posted August 21, 2007 Report Share Posted August 21, 2007 (edited) link Edited August 21, 2007 by Waddy Quote Link to comment Share on other sites More sharing options...
basher Posted August 21, 2007 Report Share Posted August 21, 2007 All pro2's come with disc mounts. Quote Link to comment Share on other sites More sharing options...
ibs_m Posted August 21, 2007 Author Report Share Posted August 21, 2007 Thanks very much The only thing I still dont get is if there is 2 types of hub - one with a single speed kit on instead of a cassette and the other made specifically only to run 1 gear and cannot run a cassette on?Help?! Quote Link to comment Share on other sites More sharing options...
Krisboats Posted August 21, 2007 Report Share Posted August 21, 2007 How can you be sure?They're very common The only thing I still dont get is if there is 2 types of hub - one with a single speed kit on instead of a cassette and the other made specifically only to run 1 gear and cannot run a cassette on?Help?!There is two types of hope pro 2 rear hubs. On is the standard hope pro 2 rear hub, basically a newer version of the old XC/bulb hubs, the other hub is the trials/singlespeed one. It is called the hope pro 2T and features hub bolts rather than QR (though a conversion kit is available), 2 more offset pawls in the freehub meaning more engagements and the hub is made with a smaller freehub body, meaning the wheel is dishless and stronger.Basically, get the trials/singlespeed version. Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted August 22, 2007 Report Share Posted August 22, 2007 I dunno what your buying it for but no matter what I was riding, I'd go for the trials version, like how I did on my trials and my street/dirt steed. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted August 23, 2007 Report Share Posted August 23, 2007 Yep, there are the two versions.The ProII, which has 4 pawls that engage simaltaniously, in a 24 tooth ratchet, giving it 24 engagements, this version has an IS 6 bolt disc mount, and a full length 9 speed freehub body, it comes standard with a QR axle, but 10mm bolts is optional.Then there's the ProIIT/ProII singlespeed, this version has 2 sets of 2 pawls, that are offset so as to engage at differnet times into the 24t ratchet, giving 48 engagements, it has a wider body (still with IS 6 bolt disc mounts) giving a dishless wheel, and as a result it has a shortened freehub body only wide enough to take 6 sprockets off a standard cassette. It comes with a spacer kit to fit a single speed sprocket too. This version comes standard with a 10mm bolted axle, but a QR is an option.Basicaly, if you can put up with running 6 or less gears, you get 24 more engagements, and a dishless wheel . Quote Link to comment Share on other sites More sharing options...
