roozor Posted August 16, 2007 Report Share Posted August 16, 2007 Just got a new magura louise, well second hand new. it's a 2006 model i think. juding by others pictures.I've been adjusting with the tpa 2.5mm allen key bolt it has on the top of the lever. the one you have to get the cap off first.even on max i have to pull the lever right in to the bars to get any action. and if i turn the tpa all the way off it doesn't even work at all.it's a factory bleed. from magura. Can i adjust the pads another way?Alex Quote Link to comment Share on other sites More sharing options...
Fishy Posted August 16, 2007 Report Share Posted August 16, 2007 How much material you got left on pads? Sounds like it needs a bleed/top up of mineral oil. Quote Link to comment Share on other sites More sharing options...
roozor Posted August 17, 2007 Author Report Share Posted August 17, 2007 How much material you got left on pads? Sounds like it needs a bleed/top up of mineral oil.bleed is fine, pads seem fine. No idea what to do! Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted August 17, 2007 Report Share Posted August 17, 2007 bleed it again, factory bleeds tend to be wanky Quote Link to comment Share on other sites More sharing options...
clarkytrials Posted August 17, 2007 Report Share Posted August 17, 2007 Have you tried pulling the leaver blade rapidly ? ( pumping ) mine dose it if i leave if foe a while then it all good ... if that dont work try topping it up Quote Link to comment Share on other sites More sharing options...
