Steve Tiller Posted August 11, 2007 Report Share Posted August 11, 2007 I want to no is it something to worry about as usually it is silent.Also if it is somthing to worry about what is it that needs replacing?If nothing needs replacing what stops the the noises coming from it?I Bought this from Second hand and was fine this morning when it was first fitted but then towards the end of the day it start making the noisesSteveP.S thank you for getting back to me so fast for people who comment this as i need the advise fast because of the ride i might miss out on. Quote Link to comment Share on other sites More sharing options...
Echo-Scott Posted August 11, 2007 Report Share Posted August 11, 2007 My mates headset does this to and all he does is spray some gt85 in it every now and again and it seems to fix it. Quote Link to comment Share on other sites More sharing options...
Mod Man Leo Posted August 11, 2007 Report Share Posted August 11, 2007 My mates headset does this to and all he does is spray some gt85 in it every now and again and it seems to fix it.NO!Grease, unless you spray gt85/wd40 then turn it ALOT then put grease in, but dont just spray em in, its not good, it gets rid of grease and thins out to quickly, like by miday tmoz will have avapirated.So Spray some GT85 in, turn itThen just lighlty grease it.Job done Quote Link to comment Share on other sites More sharing options...
Steve Tiller Posted August 11, 2007 Author Report Share Posted August 11, 2007 So what is it that is causing the clicking?If i didnt grease it is there any likly hood in damaging it if i rode it tomoro do you no?Steve Quote Link to comment Share on other sites More sharing options...
Mod Man Leo Posted August 11, 2007 Report Share Posted August 11, 2007 So what is it that is causing the clicking?If i didnt grease it is there any likly hood in damaging it if i rode it tomoro do you no?Stevenah, it wont, but get some grease if you can Clicking maybee, errm? Piece of grit, seal slipping?Beats me Quote Link to comment Share on other sites More sharing options...
JT! Posted August 11, 2007 Report Share Posted August 11, 2007 It's probably just the bearings going, it's nothing to worry about, your stem isn't going to pull away from your bike or anything like that, but it'll get worse and worse as time goes on.You can grease up the bearings, but it's only a temp solution to a perminant problem. Quote Link to comment Share on other sites More sharing options...
ilikeriding Posted August 12, 2007 Report Share Posted August 12, 2007 pop your forks out and take a look, the bottom cup of mine snaps off every month or so Quote Link to comment Share on other sites More sharing options...
Saracen Kid Posted August 12, 2007 Report Share Posted August 12, 2007 its what jt! said there going time to buy a new on soon it will last another month or so my bb does it too but i cant be arsed to buy a new one lol Quote Link to comment Share on other sites More sharing options...
mavic Posted August 12, 2007 Report Share Posted August 12, 2007 Take off forks greeeeeeeeeese top and bottom cups = problem solved. Quote Link to comment Share on other sites More sharing options...
ConnorPowell Posted August 12, 2007 Report Share Posted August 12, 2007 Yeah take the forks out, take the bearings out and put them onto a peice of rag wipe them off, wack a f**k load of grease where the bearings go, put the bearings back in and pu grease over them so they are caked in. put your forks back in and ride. Quote Link to comment Share on other sites More sharing options...
mountian goat Posted August 12, 2007 Report Share Posted August 12, 2007 I want to no is it something to worry about as usually it is silent.Also if it is somthing to worry about what is it that needs replacing?If nothing needs replacing what stops the the noises coming from it?I Bought this from Second hand and was fine this morning when it was first fitted but then towards the end of the day it start making the noisesSteveP.S thank you for getting back to me so fast for people who comment this as i need the advise fast because of the ride i might miss out on.my mtb does this, just tighten it as much as u can Quote Link to comment Share on other sites More sharing options...
