Hope Mono Trial!
Smallville
If you would like to go dual disc on a BT Raven 7.0 with a Zoo pitbull fork and you want to use 180mm rotors, do you have to use the Hope +20 adapter for the calipers or is there calipers that would fit right on. I would prefer not to use any adaptors if thats possible, and is there any diffrens between front and rear except that the levers are vice versa.
Edited by Smallville
you need a +20mm adaptor on the rear, couse the BT has a internatinel standard mount. the rear 160mm caliper is the same as a front 180mm caliper.
But if I use a 200mm front caliper at the rear, will that work with 180mm rotor? Call me an idiot but I think this is weired and annoying!
200mm caliper does not even exist... If you buy a brake with 200mm rotor on tarty you get it with +20mm or +40mm adaptor to use on the front 180mm/rear 160mm caliper
Edited by Oskar
Crap, why cant they do diffrent size calipers for every rotor. I think that an adaptor just weakens the break. I guess a 160mm rotor will be to small as a rear brake.
Just get a +20mm adaptor, they are strong.
It looks like crap though.
The lack of built in +20/+40 on the rear disc was one of the deciding factors for me not getting one. I use the Simtra ST-1 now, which has +40mm as standard, so I have a 200mm disc on the back with no adapters. I've never liked the idea of adapters. Plus, tartybikes have them on special offer for £299.99 now :)
So if I use a front 160mm caliper at the rear I will need a 140mm disc? If thats correct I rather use a +40 adaptor then a +20 one to use a 180mm disc on the rear. If you look at tartys the +40 adaptor moves the caliper on a diffrent/nicer way than the +20 one does. The +20 seams to move the caliper so far from the discmount on the frame while the +40 moves it more "up" rather than "out".
yeah sure get a 160mm front caliper and enjoy snapping the 40+ mount...
I dont think the +40 adaptor will snapp any easyer than the +20. Take a look at it, I think it will be stronger since you move the caliper up rather than out from the discmount.
http://82.110.105.16/tartybikes.co.uk/product.php?id=23
I bet you will snap it on the rear, and dont get how you can think its stronger than the +20mm, and on the rear you get braking forces in both directions also.
Wait on the new evo simtra they look awesome and you will get a +40mm mount...
