Echo Control With Chris King
SQuiT-man
Hi,
Does anyone out there use a Chris King in their control, with the heavy duty bolts?
Mine don't seem to want to fit in the frame because of the way the dropout is formed having a big flange of metal stopping the bolt from slipping in correctly..
Ive never heard of this problem before, how did anyone else get around it?
Cheers,
Scott
I had the same problem with my 07 Czar. What you want to do is grind an L-shaped cutout into the silver aluminium washer around the bolt, so when fitting the wheel you turn the bolts so that the flange of the dropout will go into the cutout and then turn the bolt slightly so that it will kind-of roll over it.
Hard to describe but this picture should say more than a thoulsand words:
http://img165.imageshack.us/img165/5919/tsaar1sy2.jpg
Hi,
Cheers,
Scott
yeh I had the same issue a while back, i ground down the bolt head and the dropout. however its best to just grind/file/ dremel the drop out.
I take it it's the alu sleeve on the fun bolts that's the problem? If so can't you just cut the whole sleeve off? I am pretty sure it makes no difference to how the bolt works, it just looks neater with the sleeve.
Im tempted to grind down the flange on the dropouts since it would cause no structural damage to the frame..
I guess if I filed the chris king bolts it'd always be damaged whenever i change frames in the future/sell my king, wouldnt want that!
Do you think this was done on purpose so chris kings couldn't be used, but deng hubs could be? Do deng bolt-through hubs use bolts whose threads are no larger than the diameter of the bolt itself (unlike King bolts, which widen at the thread, hence causing the problem)?
If so, thats a bit cheeky/clever
