Removing Split Links In Chains?
Your on a mod i can't see there being any serious problems with it. However WD40 and some play will make it that little bit looser or if you want to do a decent job take apart the links and sand the rust away if that's the problem. Or just replace the links alltogether if you have enough.
Try wd40 and once it has soaked into the links go around the chain and bend all the links in and out one by one and then it should be nice and loose and after that just spray a bit of wd40 all the way round the chain after every wash that should keep it loose and oiled
James
Edited by sandi
