Guest Posted August 9, 2007 Report Share Posted August 9, 2007 do i just screw the top cap in then hit it in with a hammer? or is there a special way?all help apreciatedcheerz,Reece Quote Link to comment Share on other sites More sharing options...
JonCongreve Posted August 9, 2007 Report Share Posted August 9, 2007 I believe that there is a proper tool, although i think that it's only a bolt with some metal on the top. All i do is out the bolt half way in the star nut, and hammer it in. Just make sure it's nice and straight with first few hits Quote Link to comment Share on other sites More sharing options...
Guest Posted August 9, 2007 Report Share Posted August 9, 2007 I believe that there is a proper tool, although i think that it's only a bolt with some metal on the top. All i do is out the bolt half way in the star nut, and hammer it in. Just make sure it's nice and straight with first few hits sounds good to me, cheerz mate Quote Link to comment Share on other sites More sharing options...
Tomm Posted August 9, 2007 Report Share Posted August 9, 2007 Just make sure it's nice and straight with first few hits Yeah. I usually stick the bolt in the star nut as it's easier to line that up straight. Hammer the bolt (not too hard in case you strip the threads though). Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted August 9, 2007 Report Share Posted August 9, 2007 i get a about 10mm deep socket and tap the star down works a treat and you dont damage top cap or possibly stripping threads Quote Link to comment Share on other sites More sharing options...
Guest Posted August 9, 2007 Report Share Posted August 9, 2007 ok then i will do this tommorow, cheerz for the help Quote Link to comment Share on other sites More sharing options...
Muel Posted August 10, 2007 Report Share Posted August 10, 2007 I usually stick the star nut in a bit, then screw the bolt in with the top cap in place, get the top cap lined up then knock it down to where you want it. Quote Link to comment Share on other sites More sharing options...
squince Posted August 10, 2007 Report Share Posted August 10, 2007 Put the bolt in the star fangle nut, and have a top cap on to, to ensure it goes in perfectly straight, just hammer it in by the nut until the top cap is on the steerer. Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted August 10, 2007 Report Share Posted August 10, 2007 http://www.tartybikes.co.uk/product.php?id=626expensive but worth it. no more bodge jobs!!!!! Quote Link to comment Share on other sites More sharing options...
Heatsink Posted August 10, 2007 Report Share Posted August 10, 2007 http://www.tartybikes.co.uk/product.php?id=626expensive but worth it. no more bodge jobs!!!!!I agree!No more bodge jobs on removing/inserting headsets either please! - Proper tools for a proper job The tools should last forever, and gradually building up a tool box will be definately worth it in the long run. Quote Link to comment Share on other sites More sharing options...
mods Posted August 10, 2007 Report Share Posted August 10, 2007 i put a bit of copper tube over the end and jus hammered it in, worked a treat. Quote Link to comment Share on other sites More sharing options...
