Saracen Kid Posted August 9, 2007 Report Share Posted August 9, 2007 how do you set gears up so they look like this:http://www.tartybikes.co.uk/image.php?imag...rge_07231ti.jpgnot likehttp://www.saracencycles.com/index.php?opt...&Itemid=185sorry to use a saracen pic but i know there wrong still love em though Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted August 9, 2007 Report Share Posted August 9, 2007 I suppsoe its just a specific mech designed to keep out of the way. Quote Link to comment Share on other sites More sharing options...
Sukoto Posted August 9, 2007 Report Share Posted August 9, 2007 shorter chain on the monty. Quote Link to comment Share on other sites More sharing options...
dangerous_dave Posted August 9, 2007 Report Share Posted August 9, 2007 you take many links out of the chain so it becomes tighter and pulling the tensioner further up. Quote Link to comment Share on other sites More sharing options...
adamant_a2 Posted August 9, 2007 Report Share Posted August 9, 2007 break the chain and place it over the largestcog ont the rear. then pull it as tight as possible and see where it would join. then add two links to this and rejoin with a chain tool or split link.good luck Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted August 9, 2007 Report Share Posted August 9, 2007 chains longerer init Quote Link to comment Share on other sites More sharing options...
_Owen. Posted August 9, 2007 Report Share Posted August 9, 2007 you can only really run a mech like that if you are running single speed, as the mech will use all positions when you have gears. but as said above the mech will be in that position if you have a shorter chain. hope i helped Quote Link to comment Share on other sites More sharing options...
sandi Posted August 11, 2007 Report Share Posted August 11, 2007 buy a short cage rear mech onza do one cheap and take links from your chain Quote Link to comment Share on other sites More sharing options...
