Netherking Posted August 9, 2007 Report Share Posted August 9, 2007 i need a new pretty cheap XC hub and spokes to build on to my old mavric rim, i'm gonna use Dt champion or something so used they spoke lenght calculator and i've filled all the fields in apart for the spoke intersection bits??? is this the spoke pattern ? 3x cross overs is the pattern i'll be using. hub, Shimano XT , Dt swiss spokes and a 117 mavric rimgot about £50 ish to get the hub and spokesany better ideas from you lot would be good cheers sorry this isn't trials relatedHarry Quote Link to comment Share on other sites More sharing options...
RobinJI Posted August 9, 2007 Report Share Posted August 9, 2007 noo.. Dont get a shitmano hub. Who wants to spend ages looking after lame loose ball bearings.I'd really recomend this hub, 18 quid, so cheeper than alot of loose ball bearing hubs, and is identical to the DMR hub that retails at 32.50. As most people will say the bearings in the DMR stuff are pretty decent. And ontop off all that its lighter than a Hope ProII. So yeah, good hub.And yeah, your right, number or intersections is exactly that, so put in 3 for a 3 cross wheel. Quote Link to comment Share on other sites More sharing options...
Netherking Posted August 9, 2007 Author Report Share Posted August 9, 2007 (edited) noo.. Dont get a shitmano hub. Who wants to spend ages looking after lame loose ball bearings.I'd really recomend this hub, 18 quid, so cheeper than alot of loose ball bearing hubs, and is identical to the DMR hub that retails at 32.50. As most people will say the bearings in the DMR stuff are pretty decent. And ontop off all that its lighter than a Hope ProII. So yeah, good hub.And yeah, your right, number or intersections is exactly that, so put in 3 for a 3 cross wheel.sorry need a rear hub! lol all planet X freehubs good?theres one 24.99 on chain reactions. and if so i need to know the diameter and the spoke flange and stuff. any ideas Edited August 9, 2007 by Netherking Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted August 9, 2007 Report Share Posted August 9, 2007 for that money..sounds like you'd be better off trying second hand have a look at the classifieds- a shimano freehub just does not last...! Quote Link to comment Share on other sites More sharing options...
