m4ttyb0y Posted August 8, 2007 Report Share Posted August 8, 2007 my front brake has snapped and my back break is leaking they are both magura hs11 so i might get some new brakes but i want powerful brakes which r pretty cheap any suggestions and pease can someone please tell me how to pedal hop the easiest way possible and whats the best way to learn Quote Link to comment Share on other sites More sharing options...
Trix Posted August 8, 2007 Report Share Posted August 8, 2007 What has actually snapped on the front brake the lever? if so buy a replacement I run a hs11 on the rear and it works real good, set it up properly get some tar on the rim and its great. find where the rear is leaking and buy the replacement part it'll probably be cheaper. With pedal hoping im guessing you mean pedal kicks? I leaned just by practicing them on a kona shred at first you probably pedal and lift the front end up and then just pedal again hardly moving the rear wheel off the floor. Just keep at it and it'll come in time. It may be easier to learn how to hop on the rear wheel first? but not too sure. Good luck, Rik Quote Link to comment Share on other sites More sharing options...
mod-92 Posted August 8, 2007 Report Share Posted August 8, 2007 n my opinion I would say get 2 new HS33 (Tartybikes is a good place) if they aren’t Bled already get them well bled and set up properly either with a Harsh grind with plasmatic CRM’s (to do this you need a grinder and run it around the rim at a 90 degree angle. There are many instructional videos on you tube and around the forum to show you how to do this) or a smooth rim with green rock pads.Green rock pads: http://www.tartybikes.co.uk/product.php?id=10010 Plasmatic CRM’s: http://www.tartybikes.co.uk/product.php?id=17Rim grind video: http://www.youtube.com/watch?v=iAtdLzUZyT0tom Quote Link to comment Share on other sites More sharing options...
m4ttyb0y Posted August 9, 2007 Author Report Share Posted August 9, 2007 (edited) thanks for your help il see if i can fix my maguras first then if i cant fix them il get some new onesand i have snapped the part next to the clamp that goes around the barsand il get some new pads and the part thats leaking is because my seals had it lol Edited August 9, 2007 by m4ttyb0y Quote Link to comment Share on other sites More sharing options...
