Onza T Comp
Josh PWND
i guess your kinda new but if u mean will the geometry be right then yes it will all work and all the parts u listed will fit but realy you need to try it for yourself (Y) and the t comp and tpro are all the same as last years t pro and they ride nice so your should be good but eventualy the wheel need repalcing as they go realy easily (N) hope that helps m8 .
