RossMcd Posted August 6, 2007 Report Share Posted August 6, 2007 i have an Echo rear disc hub and it seems to have a bit of play in it. can anyone help me on how to get rid of this because it is starting to get on my nerves! Quote Link to comment Share on other sites More sharing options...
NileBrown™ Posted August 6, 2007 Report Share Posted August 6, 2007 (edited) Wheres the play coming from? Does the shell and bearings move along the axle? Edited August 6, 2007 by nile71091 Quote Link to comment Share on other sites More sharing options...
RossMcd Posted August 6, 2007 Author Report Share Posted August 6, 2007 Im not too sure... Quote Link to comment Share on other sites More sharing options...
ogre Posted August 6, 2007 Report Share Posted August 6, 2007 Checked all the bolts are tight? 'cause disk bolts rattle loose when you first put disks in loctite em? Check the wheel (for loose spokes, or a crack ) Check the disk calliper bolts See if the pads move in the caliper? Quote Link to comment Share on other sites More sharing options...
NileBrown™ Posted August 6, 2007 Report Share Posted August 6, 2007 Im not too sure... ok....Well basically on my non disk rear echo, my shell and bearings kept on moving along the axel. This was because the hub was designed to be used with snail cams on the inside and that would be used as a spacer. However because I have a Zona Zip, theres no snail cam screwholes which means I have to use tensioners. So, because the snail cam spacers were not there, it meant the hub would have a tendancy to move around along the axel. So one day, I busted down to my local wilkinson's and bought a pack of curtain spacers that would fit snug on my axel and it solved the problem That was a 39p bodge that actually worked! Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted August 6, 2007 Report Share Posted August 6, 2007 ok....Well basically on my non disk rear echo, my shell and bearings kept on moving along the axel. This was because the hub was designed to be used with snail cams on the inside and that would be used as a spacer. However because I have a Zona Zip, theres no snail cam screwholes which means I have to use tensioners. So, because the snail cam spacers were not there, it meant the hub would have a tendancy to move around along the axel. So one day, I busted down to my local wilkinson's and bought a pack of curtain spacers that would fit snug on my axel and it solved the problem That was a 39p bodge that actually worked!exactly the same problem as a mate! the bearings come out of the hub shell then it wobbles, only way you can sort it out is to take wheel off, hit the bearings back into the hub, get some thing to clamp and hold the bearings in. The ones you get on them are weak and they dont hold the bearings in! orrr just live with the wobble...Tim. Quote Link to comment Share on other sites More sharing options...
RossMcd Posted August 6, 2007 Author Report Share Posted August 6, 2007 Checked all the bolts are tight? 'cause disk bolts rattle loose when you first put disks in loctite em? Check the wheel (for loose spokes, or a crack ) Check the disk calliper bolts See if the pads move in the caliper?sorry i forgot to mention im not actually running a disc it is just a disc hubok....Well basically on my non disk rear echo, my shell and bearings kept on moving along the axel. This was because the hub was designed to be used with snail cams on the inside and that would be used as a spacer. However because I have a Zona Zip, theres no snail cam screwholes which means I have to use tensioners. So, because the snail cam spacers were not there, it meant the hub would have a tendancy to move around along the axel. So one day, I busted down to my local wilkinson's and bought a pack of curtain spacers that would fit snug on my axel and it solved the problem That was a 39p bodge that actually worked!haha!! I have a zona zip too! i guess ur idea mught just work. Ill give it a try asap Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 6, 2007 Report Share Posted August 6, 2007 Solution... don't take bits off your hub! Quote Link to comment Share on other sites More sharing options...
RossMcd Posted August 6, 2007 Author Report Share Posted August 6, 2007 Solution... don't take bits off your hub!Thats the way i got it when i bought my bike Quote Link to comment Share on other sites More sharing options...
Alex-Mitchinson Posted August 6, 2007 Report Share Posted August 6, 2007 I have the exact same problem with my adamant fixed hub, i cant use snail cams because there isnt enough adjustment on them and if i take a link out my chain it becomes wayyyy to tight. I am using chain tugs so i guess this is why I have the free play then. Is it ok to leave it how it is? If not where should I put the spacers? Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted August 6, 2007 Report Share Posted August 6, 2007 because there isnt enough adjustment on themhttp://www.tartybikes.co.uk/product.php?id=34 ?Or would they not pull back enough? Fair play if it's them not pulling back enough. Quote Link to comment Share on other sites More sharing options...
