Help: Getting Bolt Out Of Cranks
Simpson
I tryed quite a lot to to get the bolt out, its rounded and really wont come out, tryed the trick of putting in a bigger allen key and gluing it in.... tryed grinding across the bolt to get a flat headed screwdriver in there.... but by the other crank bolt i think its doe up pretty bang tight.....
Any other? im bang out of ideas now...... If not ill just mask the cranks when i spraying but want to do a good job onit.....
grind through the bb :)
looks like its a masking jobbi !
No and no i dont wanna just mask as i wanna get a proppa spray'idge on the rear triangle
Drill the centre of the bolt out, then tap it away.
Futher explaination??? edit... i dont wanna ruin the cranks or anything.... just get the bolt out preferably
Edited by Simpson
Just an Idea, put if you used a 7mm drill bit you could drill out the centre of the crank bolt, then use a tap to clear the rest of the thread out of the bb. Mind you, when I last used a tap in a bb it snapped because I use one slightly too big.
If its a LH thread simply drill the bolt with something like a 6mm or 8mm (not all the way through, you need the tap to bottom) and thread in a m8/m6 tap. if the bolt dosen't go at 1st grind /drill off the head of the bolt to release the pressure then try tapping down again. DONT apply too much force on the tap as if that snaps you'd need a solid carbide drill bit to get that out and probably a magnet/bench drill.
If the bolts a RH thread then got to a decent hardware store or look on the web for an "Easy out kit" and a hss 8mm drill, carefully drill out the center of the bolt until you deep enough to get an easy out in, grind/drill the top off the bolt and then simply push down and turn until the easy out turns the bolt out.
(easy out)
As was said above if it is a bmx bb (and not a euro bb) just push the axle through grip the axle in a vice, itll make the job sooooo much easier :)
Edited by joshywa
Dont worry done it!!! just took off the other crank arm, then hammered though and and other crank arm fell off SWEEET
You must of been kicking yourself when you realised you could do that :P . To be fair, when i read the thread, i actually never thought about doing that haha.
Well i was going to jack it in and not bother spraying the dam thing, after angle grinding the bolt to try to get a screw driver in there... was just so bloody infuriated, popped out a treat as well!!! and the kid gave me a BB tool or summink which made me think, well i must have to use that... but nope just a hammer did the job! im chuffed spent 3 hours sanding the frame and its all ready to spray 2morra :)
