Sam O Posted July 31, 2007 Report Share Posted July 31, 2007 Hi, just recently when I put the front brake on to stop and endo and all that, the bike creaks loads at the front end. I've tightened the headset and all of the brake, handlebars etc... but the creaking continues. I was wondering if anyone knows what the creaking could be and how to stop it.Thanks Sam Quote Link to comment Share on other sites More sharing options...
abtrials Posted July 31, 2007 Report Share Posted July 31, 2007 probably you bars are about to snap they make horible noises when they are on there way Quote Link to comment Share on other sites More sharing options...
dave85 Posted July 31, 2007 Report Share Posted July 31, 2007 I had a creak on a brand new set of echo bars (and the old style stem), solved that by cutting a piece of paper so it would just wrap once round the bars. How old are the bars and what are they? Quote Link to comment Share on other sites More sharing options...
RossMcd Posted July 31, 2007 Report Share Posted July 31, 2007 it depends on how the bolts are tightened on the bars. if it is four bolts then try tightening them equally. that should do the trick. Quote Link to comment Share on other sites More sharing options...
t33zr Posted July 31, 2007 Report Share Posted July 31, 2007 Grease between every place its posible metals creeking together...! Quote Link to comment Share on other sites More sharing options...
loffa Posted July 31, 2007 Report Share Posted July 31, 2007 You can try putting some grease on the bolts that hold the bar to the stem. They tend to creak when not greased.That or your fork/stem/bar is about to snap. Quote Link to comment Share on other sites More sharing options...
Nick Garland Posted July 31, 2007 Report Share Posted July 31, 2007 Grease everything from the steerer tube to the bolts and bar clamps etc. I had this problem before applied some grease and problem solved.Not sure why it does this, guess is trying to move slightly when it cant due to it being dry so apply some grease and its allowed that very slight amount of movement. Quote Link to comment Share on other sites More sharing options...
Sam O Posted July 31, 2007 Author Report Share Posted July 31, 2007 Thanks for all of the advice guys! I will do everything that you have recomended and if all of that fails I'll have to take it to the bike shop. Quote Link to comment Share on other sites More sharing options...
NileBrown™ Posted July 31, 2007 Report Share Posted July 31, 2007 Check that your headset cups are slightly lubed or greased and check for a flared headtube - my headtube on my zona is flared and was creaking for ages. I thought it was my front brake but on closer inspection, it was my headset cups moving and creaking within the tube. So.. to stop this I simply wrapped a thin layer of tape around my headset cups and re-inserted it back into the frame, and now my bike is silent (apart from the freewheel and brakes) Just worth a look as it could solve your problem Quote Link to comment Share on other sites More sharing options...
Hendrix Posted July 31, 2007 Report Share Posted July 31, 2007 are you sure you're not just fat ? My forks do that on my commuter bike. And I did encounter it once before on a jump bike, shortly after.... they snapped clean off :| Quote Link to comment Share on other sites More sharing options...
