Cracked Frame Help!
rite dudes bad news iv cracked my frame just before the summer riding which sucks what makes it worse i have no money to replace it was just wondering wether anyone has any ideas on welding it and what type of welder to use its an ashton justice 20 and its cracked round the bottom tube at the rear end on the drive side i do know welding will not fix the problem for good but will at least pospone the inevatable well maybe at least till the end of summer i would realy apreciate the help guys need help within the next few days so make it quick
yeh someone i know got a weld done to there frame, they got it welded at some car place i think so it wasnt anything special and it seems to be holding.
Well i have done fabrication and i would strip down the paint to bare metal and the i would get someone to arc weld it and tht is a sort of non heat welding as the reactions occurs on impact with the metal.
That is you best option other then that i don't know sorry mate.
Could always sed it back back but i jus find it too much hastle
Upload a piccy of the crack.
Joshx
