T.McMillan Posted July 30, 2007 Report Share Posted July 30, 2007 heyjust wanted to know why on tarty's the monty hubs are 110mm and most of the deng are 116mm, will monty hubs run in deng frames? and will deng hubs run in monty frames? why are they different spacing why cant they be the same?thanks in advance Quote Link to comment Share on other sites More sharing options...
kid creole Posted July 30, 2007 Report Share Posted July 30, 2007 i think the extra space is for the snail cams , i think. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted July 30, 2007 Report Share Posted July 30, 2007 monty frames are thinner so you use their hubs rather than someone elses.dont put a 116 in a monty by stretching it to fit, it will just crack your frame very quickly Quote Link to comment Share on other sites More sharing options...
Greetings Posted July 30, 2007 Report Share Posted July 30, 2007 Monty Ti hubs are 106mm and the Ti frames are 106mm (snail cams go on the outside).Pr frames have 110mm hub spacing and you can use all normal hubs in those frames but the snail cams need to go on the outside116mm is the hub spacing for frames that use snail cams on the inside and 110mm hubs. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 30, 2007 Report Share Posted July 30, 2007 Monty Ti hubs are 106mm and the Ti frames are 106mm (snail cams go on the outside).Pr frames have 110mm hub spacing and you can use all normal hubs in those frames but the snail cams need to go on the outside116mm is the hub spacing for frames that use snail cams on the inside and 110mm hubs.Not if you put monty spacer's on a normal hub , or machine/file down the spacer's a few mm each side. I have a monty quando hub and a try all hub, both are the same width, it's the spacer's that are differant.... Quote Link to comment Share on other sites More sharing options...
sidehop Posted July 30, 2007 Report Share Posted July 30, 2007 I run that exact hub on an adamant a3, Had to space it out abit. Overall its perfect now.So answer is, Yes. Quote Link to comment Share on other sites More sharing options...
