Maguras And Different Fluids?
The Stig
pretty sure it will be the same 'spongyness' whatever liquid you use and it wont compress unless you have air in the system, then you have a shit bleed. water is just less dence than oil so pulls easier. but aslong as you have a good bleed, it doesnt really matter what you use.
oh and do not use d.o.t as it will rape the seals
yeh water and antifreeze is supposedly good, i have felt a water bleed and it was mega and when i went back to my bike it felt like a sponge, quite litrally
well personaly, i don't think water's good because, my friend sent hgis bike to the shop, he re-filled it with water, they froze in the winter.
but he left his bike o0utside during the cold weather outside (at night), lol!
Edited by boo rider
with the water method, why not sub merge the brakes in a bucket of water and anti freeze, put the clear tube and seringe on the lever side, and jsut suck the water in? then put the grub screw back in the caliper end, remove the tube and put the screw in the lever and ur done? seems too simple, would it work?
small tip to keep air out of the system iincluding the air desolved in the water. very simple, boil the water before you bleed it. pour it into a jug add the anti freeze, and bleed with that.
All that would do is warm the water up and give you slightly less to bleed the brake with.
nope, water has air disolved in it, the only way to get rid of that, is to boil it, try it, will give an even stiffer brake!
