Um, An 07 Czar Possibly...
Bigman
Look:
Spec:
Czar 07 long
Atomz forks
Onza 30inch riser bars
Tryall 130 x 20deg stem
Cane Creek S3 headset
Front hope XC built to DX32 with large sguare holes and drilled sidewall
Rear CK classic built to Echo 07 with 12square holes (wanted to ride :P) hope SS kit with 16t sprocket
Rear avid ultimate with linear slic cable, SD7 lever, home made adapters and koxx green rubber
Front Hope mono trials 07 190mm with black lever blade
Middleburn ISIS cranks with 18t cloud9 bash
Gusset slipjim pedals
Echo ISIS internal BB
Home made spring steel tensioner
Maxxis high roller 2.5ST rear and 2.35 single ply ST front
ODI longnec grips
Adam
Noooo.. why did you grind down the frame? Theres a much better solution for it: You can see an L shaped cutout on the funbolt washer at about 5'o'clock.
Other than that, nice looking bike you've go there. How's the rear brake? How does it feel when running boosterless? I'm running a Dengura on my Czar and the frame flexes quite a bit without a booster. And I have always thought that vees make your frame flex easyer than maggies..
To Boum: It rides like nothing i have ever ridden before! it realy is very good!
To Loffa: I didn't realy want to grind my fun bolts (didn't thino of it either :P) as if you do you loose an amount of area that is used for clamping the wheel in....
Looks good only downside I can see is that they are VERY common at the moment, but that shouldn't matter if it rides nice.
Yeh, they are a little more popular that i was expecting :P
Adam
Also got dengura on my czar and it doesn't flex an mm. Control was moving a bit under pressure of brake, this does not.
Cool bike Adam
Cool bike Adam
you sir, are either lying, or have lame fingers!
ANY frame WILL flex without a booster! and the control is one of the stiffest ive found without a booster so far. certainly less so than the 07 czar i rode.
looks nice ad. looking forward to a ride!
LOVE IT! Looks well smart and nice to ride. I wouldn't mind that frame if I was to build my own 26" as I wouldn't mind doing but I never rode 26" trials before, lol.
Ps. Noone round here rides 26"
~Matty
Erm... What about me, robin, rich, tom and kev?
Yeah man, looks amazing, get your arse back to Shropshire soon so we can ride welly.
lower stem ad, looks lush though
Not at all, Jamie (pompey riders) is way to low, also when i was riding the control i had an echo 130 x 15mm stem right at the top of the forks, ie high front end, for this bike to feel right with the extra bb rise i had to have it higher than the echo, hence the height!
Glad everybody likes it.
Joe, i shall be up at the start of sept, as i have a re-sit at college (Y)
Adam
