What Do You Think?
chris13
Well i want a new bike for my birthday so i need to start nagging soon. I really like the look of the Adament A1 and have made up this spec. what are your thoughts? what would you change?
If it helps, im 5 foot 7 (ish)
- Frame: Adamant A1 (long) Vertical Drop outs
- Forks: Echo Control '07 (4Bolt/Disk)
- Front hub: Adamant CNC Disc
- Rear hub: Adamant CNC Fixed
- Head set: Adamant CNC
- Crank: Echo 7075 CNC
- Freewheel: Try-All 108.9
- Bashring: Echo 7075 18t
- Front brake: Hope Tarty Trial 200
- Rear brake: Magura HS33 2005
- Brake clamps: Adamant CNC
- Brake pads: Plazzie
- Brake booster: Echo 4-Bolt
- Front rim: Try-All Front 26"
- Back rim: Try-All Rear 26"
- Spokes: Sapim Race DB
- Wheelbuilds: Tarty
- Rim tape: Try All
- Inner tube (f): Maxxis Welterweight
- Inner tube ®: Maxxis Welterweight
- Front tyre: Maxxis
- Back tyre: Maxxis
- Stem: Echo Hifi ----------------------------------would like advice
- Grips: Tarty Raffle Grips
- Handlebars: Adamant Riser Bar----------------would like advice
- Chain: KMC K710
- Rear Sprocket: Echo 15t
- Tensioner: 74Kingz
- Bottom bracket: Echo Internal ISIS
- Pedals: Echo VP-458a
What would you recomend for the bar and stem for someone of my size?
Is there anything on that list you would change?
This will be my first good trials bike :D as A.T.M I have a mission prodigy :(
there gunna cut it in half though, get the front for birthday, back for christmas, probs get it half way between, so late november/early december. i know it is a long time in advanced, but i always do it just to make sure i get it :P
sorry mandry, theres no room for your bike :(
anyone gunna tell me what they think of the bike?
Edited by chris13
err mind if i limit you to what tarty bikes sell since they do them deal builds.
monty urban looks about right, shorter than what i have on my mtb, and the bike is longer.
Edited by chris13
look in the onza stem section, pazzaz are owned by onza, so they are on tarty
do you mean 16t freewheel grantstop? and what gearing on the rear then?
yer 120x17 sounds good with zoo riser bars
oh and i ment horizontal drop outs with the 116mm spacing at the rear, got confused last night lol
Edited by chris13
You want 18t on the front and 16t on the rear, nicest gearing ever
well my adress has 3 places on it lol, reading, wokingham, winnersh, im in winnersh. i live in sherwood grange wich backs onto winnersh triangle industial estate.
i would have thought 18 15 would be best? 18 16 sounds a bit low i thought on a 26 the ratio i ment to be 1.2 (drive gear devided by rear sprocket/ free wheel), and 20" needs to be 1.5 cos of the diference in wheel size?
never knew
never knew
pwetty polly...
u know reading is better right?
might pop down to newbury some time. you guys got msn?
and on the question of a grind i was kind of hoping to keep my pink rims, well pink :D
planning a black and pink bike :D :D :D
Ha ha, Yeah reading is much better but never ridden there Because knowing me IL end getting lost and end up calling the AA or whoever you phone when you get lost, yeah my Msn is connor--23@hotmail.co.uk.
Nice one, O and by the way pink rims would look mint with black bike .
Connor (Y)
Edited by OnzaTvee23
i do love black and pink together :P ive got a black and pink body shell for one of my model cars :D
does anyone have experiance with disc brakes, cos they look pretty vunerable, has anyone ever bent a disc, smashed calliper?
conner, im more likly to get lost, i have never used the train on my own, and even then i end up in the rong place :(
im probly going down winnersh triangle later if anyone wants to come probs be there arround 2
