Decontaminating A Disc Brake
mr joe
Hi a couple of days ago i was cleaning my bike and then used a bit of wd40 on my bike and acidental got it on my disc rotor. (N) Now my brake does not stick solid to the rotor and slips. Does anyone noe how i can sort this problem out for you will be doing me a big favour.
All coment will greatful
Joe
Boiling hot soapy water for the disc, soak for around 15 mins, then put in the oven for about the same time.
Simply cook the pads as said above, but don't over cook them lol.
For better braking performance, assemble together, try hot water on the disc and ride around or down a big hill with the brake on (Y).
lewis
Clean the disk as best as you possibly can; wipe it all clean with soapy water and then cook it for a while in the oven. For the pads put them over the hob for a bit so that the oil can burn off. Afterwards try and sand them a little as this will remove any surface oil that may be left on the pad. If none of this works then you will probably need new brake pads as the oil has seeped to far into them for cleaning.
Hope I've helped (Y)
Ride really fast downhill and pull the brake enough to warm it up but not slow you right down - burn any crap off!
I've never had wd40 on it but stuff like coke seems to come off easy - I know oil is different, but if you haven't spilt much it should come off ok :)
Hi there, I did something pretty similar to mine! but it involved oil ^_^ I gave the pads a quick sanding with some harsh sand paper, preferably the green textured sand paper, and sanded the pads down until they we're fair harsh. After that i washed the disk with hot soapy water :) and did the usual bedding in process of riding with the disk on and covering it in water etc untill it was steaming :).
The above method may seem a little bit brutal but it does actually work very well
all you have to do is:
remove pads
get a blowtorch
ignite blowtorch
put the flame on the pads for a couple of seconds then remove it off the pads
let the pads cool down
repeat process till no more black smoke comes off.
