onza boy 46 Posted July 22, 2007 Report Share Posted July 22, 2007 hi, Ive just moved ma levers further down the bars as this feels more comtable, but when im riding the grips constantly move further down the bars, any one got an idea how to stops my grips slipping? cheers Quote Link to comment Share on other sites More sharing options...
ilikeriding Posted July 22, 2007 Report Share Posted July 22, 2007 hi, Ive just moved ma levers further down the bars as this feels more comtable, but when im riding the grips constantly move further down the bars, any one got an idea how to stops my grips slipping? cheersLOL glue/hairspray, gripstoppers from tarty, jubilee clips, tape...ect Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted July 22, 2007 Report Share Posted July 22, 2007 Disc brake cleaner, OR ODI lock on grips!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Greetings Posted July 22, 2007 Report Share Posted July 22, 2007 or whack a lot of insulating tape around your bars just behind the grips, that should stop them from moving Quote Link to comment Share on other sites More sharing options...
grantallsop Posted July 22, 2007 Report Share Posted July 22, 2007 monty brake spray works amazing Quote Link to comment Share on other sites More sharing options...
Ross Gardner Posted July 22, 2007 Report Share Posted July 22, 2007 tar the bar? or use hairspray Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted July 22, 2007 Report Share Posted July 22, 2007 Normal gel DOESNT WORK! I mean stuff like wella /VO5 etc etc Quote Link to comment Share on other sites More sharing options...
ilikeriding Posted July 22, 2007 Report Share Posted July 22, 2007 or whack a lot of insulating tape around your bars just behind the grips, that should stop them from movingBe a bit weighty, don't you think? Quote Link to comment Share on other sites More sharing options...
Rhys Bradford Posted July 22, 2007 Report Share Posted July 22, 2007 I've used hairspray works a treat Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted July 22, 2007 Report Share Posted July 22, 2007 Petrol. Quote Link to comment Share on other sites More sharing options...
JaMmY Posted July 22, 2007 Report Share Posted July 22, 2007 LOCK ONS OR TAPE!!!! Quote Link to comment Share on other sites More sharing options...
trialschallenger Posted July 22, 2007 Report Share Posted July 22, 2007 if u dnt fancy buying n e thing y not cut an old pair of grips up and put it inbetween the lever and the actual grip t'is what ive done and its mustard Quote Link to comment Share on other sites More sharing options...
Greetings Posted July 22, 2007 Report Share Posted July 22, 2007 Be a bit weighty, don't you think?You must be joking Much less than locks made of metal Quote Link to comment Share on other sites More sharing options...
little bmxer boy Posted July 22, 2007 Report Share Posted July 22, 2007 Just get some of these http://www.chainreactioncycles.com/Models.aspx?ModelID=433 Quote Link to comment Share on other sites More sharing options...
BRISA RIDER! Posted July 22, 2007 Report Share Posted July 22, 2007 Hay i had the same problem i put two cable ties on the inside of the bars then put the grips on. No more slippy grips!!!! cheers Jamie Quote Link to comment Share on other sites More sharing options...
RicH_87 Posted July 22, 2007 Report Share Posted July 22, 2007 buy grips that have an end on them, rather than just being a tube. Quote Link to comment Share on other sites More sharing options...
Janson Posted July 22, 2007 Report Share Posted July 22, 2007 Lock-on grips are horrible for trials. You wear through to the plastic core and then the little tabs that go into the metal lockrings snap off.I use normal grips on a CLEAN bar, with the lock-on rings on either side. Grips don't go anywhere this way. Quote Link to comment Share on other sites More sharing options...
onza boy 46 Posted July 23, 2007 Author Report Share Posted July 23, 2007 hi, about the hair spray, is there a brand thats better for sticking or is it all the same? cheers Quote Link to comment Share on other sites More sharing options...
georgieporgie Posted July 23, 2007 Report Share Posted July 23, 2007 hi, about the hair spray, is there a brand thats better for sticking or is it all the same? cheersIve used about 3 diffrent types i dont think it does make a diffrence.i use a clean bar hair spray and one loc on thing works fine with raffle grips no slippage! Quote Link to comment Share on other sites More sharing options...
NileBrownâ„¢ Posted July 23, 2007 Report Share Posted July 23, 2007 Seriously, everytime I buy new grips all I use to keep them on is good ol' Saliva! I mean your body makes it so its free! Just spit into your grips and swirl it about around the inside of your grip and then slide on and after about an hour it goes sticky and if you leave it overnite they stay on Well thats what I did with my foam grips anyway and they don't move at all. Quote Link to comment Share on other sites More sharing options...
Janson Posted July 23, 2007 Report Share Posted July 23, 2007 The thing with most hairspray is that it is not very water resistant. So when water comes inside the grip they slip again. As I posted earlier I prefer clean bar and clean grip, but some kind of alcohol also works wonders. I used Isopropanol, but I'm sure Vodka or whatever is fine. Quote Link to comment Share on other sites More sharing options...
Ryan. Posted July 23, 2007 Report Share Posted July 23, 2007 tar the bar? or use hairsprayexactly what i use but tar makes it a mission to get the grip back on! Quote Link to comment Share on other sites More sharing options...
Aaron_W Posted July 23, 2007 Report Share Posted July 23, 2007 i had this problem but what i done was put black tape on the inside and it stopped it. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted July 23, 2007 Report Share Posted July 23, 2007 Lock-on grips are horrible for trials. You wear through to the plastic core and then the little tabs that go into the metal lockrings snap off.I use normal grips on a CLEAN bar, with the lock-on rings on either side. Grips don't go anywhere this way.YepSeriously, everytime I buy new grips all I use to keep them on is good ol' Saliva! I mean your body makes it so its free! Just spit into your grips and swirl it about around the inside of your grip and then slide on and after about an hour it goes sticky and if you leave it overnite they stay on Well thats what I did with my foam grips anyway and they don't move at all.And yepNever ever had a problem with lock-ons for any type of riding, There awesome if you ask me. At the moment though I've just got a very clean bar, with a very clean grip slid onto it with nothing but force, and old lock-on collars on the inside to stop them going anywhere or any water getting under them. Never move.Also run barends that cover the end of the grip, like the BMX style ones, not just little plugs, that way they stop water getting under the ends as much. Quote Link to comment Share on other sites More sharing options...
Simpson Posted July 23, 2007 Report Share Posted July 23, 2007 but I'm sure Vodka or whatever is fine.Seems like a terrible waste to me.....just clean your bars with water spit in the grip twirl it round flick the spit out and give it some beans to get it on the bar.... instantly rideable...... only works if your grips are newish and not some foamy shit Quote Link to comment Share on other sites More sharing options...
