Brake Boosters , Why?
Toby3448
i have a 4 bolt brake booster but i see so many brakes running without , i wonder if i really need the booster.
i guess it would make the brake stronger with it ?????? currently its only got 2 bolts actually running threw the booster and the other two not not , so should i leave it take it off or get two more long bolts??
please advise with reason
just take it all off, unless its a really flexy frame.
new frames dont flex much so dont need them.]
it will also make your brake noisier if you like that (Y)
