eskimo Posted July 22, 2007 Report Share Posted July 22, 2007 LINKWhat is this? I take it theres not actually anything special about it but anyone used it?I was thinking of purchasing it for a try. Quote Link to comment Share on other sites More sharing options...
trial-biker-ryan Posted July 22, 2007 Report Share Posted July 22, 2007 (edited) Pointless really... your just paying for the brand.. you could get the same type of ting from any motorcycle shop or similer alot cheaper Edited July 22, 2007 by trial-biker-ryan Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted July 22, 2007 Report Share Posted July 22, 2007 get chainsaw blade oil, does the same thing Quote Link to comment Share on other sites More sharing options...
eskimo Posted July 22, 2007 Author Report Share Posted July 22, 2007 I thought so. Cheers. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted July 22, 2007 Report Share Posted July 22, 2007 Spray lube + double disc is a baadd combination. Surely Monty would know this, leading the whole double disc thing and all.Looks like its nothing special at all, like said, anything like chainsaw blade oil, or even just Finishline dry lube if you don't wanna get the stuff all over the place. Finishline do a wax one too which evaporates to leave a wax coating all over the chain which is pretty funky. Quote Link to comment Share on other sites More sharing options...
Greetings Posted July 22, 2007 Report Share Posted July 22, 2007 Got that with a consignment a couple of days ago as a gift, haven't used it yet, didn't even know what it was for.Bare in mind that Monty doesn't make parts/accessories for street trials. It's probably a spray for people who ride lots of natural in all weather conditions. Quote Link to comment Share on other sites More sharing options...
basher Posted July 22, 2007 Report Share Posted July 22, 2007 Im guessing there will be other products like it, but not many as it isnt like a conventional lube. It seems a good idea especially for in hot countrys where the floor is dry and dusty and dust and dirty will stick to normal chain lube on your chain. So it is a good idea i think.Its only a bad combination if your silly enough to use the spray near the disk if you put the lube ect on at the cranks end then you dont get it all over your disk or rim. Quote Link to comment Share on other sites More sharing options...
ogre Posted July 22, 2007 Report Share Posted July 22, 2007 get a big can of gt85 probably the same stuff only cheaper (i'm right thinking gt85 is the one that leaves a layer of lube after it's dry aren't i ?) Quote Link to comment Share on other sites More sharing options...
Guest Posted July 22, 2007 Report Share Posted July 22, 2007 It's VERY useful on motorbikes, I use spray grease all the time on my motorbike chain, but yeh, it's a bit overkill for the trials bike, I think i've oiled my chain once, and actually wiped most of the oil off afterwards..... Quote Link to comment Share on other sites More sharing options...
Greetings Posted July 22, 2007 Report Share Posted July 22, 2007 get a big can of gt85 probably the same stuff only cheaper (i'm right thinking gt85 is the one that leaves a layer of lube after it's dry aren't i ?)nope, actually it removes all the lube from the chain Quote Link to comment Share on other sites More sharing options...
ogre Posted July 22, 2007 Report Share Posted July 22, 2007 nope, actually it removes all the lube from the chain oh i got bullshitted good. f**king halfords Quote Link to comment Share on other sites More sharing options...
Greetings Posted July 22, 2007 Report Share Posted July 22, 2007 oh i got bullshitted good. f**king halfords It's the same stuff as WD40? If not, you might be right. Quote Link to comment Share on other sites More sharing options...
ogre Posted July 23, 2007 Report Share Posted July 23, 2007 (edited) It's the same stuff as WD40? If not, you might be right.i'm not sure says summert about teflon on the can but nothing about coating it. mehTeflon-Plus dry lube has synthetic oils to set up dry and clean while keeping Teflon particles in suspension Edited July 23, 2007 by ogre Quote Link to comment Share on other sites More sharing options...
willy wonka Posted July 23, 2007 Report Share Posted July 23, 2007 It's the same stuff as WD40? If not, you might be right.GT85 took over WD40 so yeah, its the same Quote Link to comment Share on other sites More sharing options...
Muel Posted July 23, 2007 Report Share Posted July 23, 2007 GT85 is still made?! I have both because GT85 has a lower oil content and is good for polishing stuff, WD40 is better for lubricating stuff. It does lubricate, but doesn't stick all the shit to your chain which will wear it out quicker. Quote Link to comment Share on other sites More sharing options...
eskimo Posted July 23, 2007 Author Report Share Posted July 23, 2007 WD40 a lube? Pah Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted July 23, 2007 Report Share Posted July 23, 2007 WD40 and GT85 are both pants as a lube... The Monty Chain Spray is similar to the Finish Line Dry Wax someone mentioned above, works great, certainly better than *insert random household oil*. The idea, as Hudson said, is that you spray it on wet, the solvent evaporates and this leaves a dry waxy coating on your chain which doesn't attract dust and crap. Pretty sure it says exactly that on the site actually... haha, sorry for repeating myself.Ads Quote Link to comment Share on other sites More sharing options...
Token Posted July 23, 2007 Report Share Posted July 23, 2007 (edited) GT85 contains Teflon where as WD40 doesn't, WD40 is a water dispersant for freeing up seized bolts or chains because it penetrates. GT85 does a similar thing but I think it lubricates better because of the Teflon (which is non-stick an slippery).edit: anyone know how a dry wax would lubriacte your chain? Can't imagine it being very slippery. Edited July 23, 2007 by Scopse Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted July 23, 2007 Report Share Posted July 23, 2007 Doesn't need to be slippery, all it needs to do is provide a barrier between the two metal surfaces - if you plastic-coated your chain that would work amazingly, it's just it wouldn't stay put very long... Quote Link to comment Share on other sites More sharing options...
mods Posted July 23, 2007 Report Share Posted July 23, 2007 get a big can of gt85 probably the same stuff only cheaper (i'm right thinking gt85 is the one that leaves a layer of lube after it's dry aren't i ?)ha ha no i wouldn't put that on your chain! Quote Link to comment Share on other sites More sharing options...
joe b Posted July 23, 2007 Report Share Posted July 23, 2007 WD40 and GT85 are both pants as a lube... The Monty Chain Spray is similar to the Finish Line Dry Wax someone mentioned above, works great, certainly better than *insert random household oil*. The idea, as Hudson said, is that you spray it on wet, the solvent evaporates and this leaves a dry waxy coating on your chain which doesn't attract dust and crap. Pretty sure it says exactly that on the site actually... haha, sorry for repeating myself.AdsI need some of that for when im at Buthiers/Koxx Days, next. Because the amount of sand you chain collects at that place is unreal; it can lead to your chain snapping, too - as Stan found out ...Cheers,Joe. Quote Link to comment Share on other sites More sharing options...
