Hope Disk Problem
ogre
i can't put my front wheel back into the forks/disk calliper i think the pads have moved in (i recon my dad pulled the lever when he took my bike out of the car) how do i sort it out? (i don't really wanna wedge a screwdriver into the pad+beast it back) sorry for sounding a bit newbish i'm just scared of killing an over-priced brake, oh how i miss my avid :$
(i recon my dad pulled the lever when he took my bike out of the car) (i don't really wanna wedge a screwdriver into the pad+beast it back)
If your wheel aint going in, then it's cos your lever has been pulled and so your pads have moved closer. Only solution is to push the pistons back into their bore caps. Either use something to wedge between the pads and open them out, or take the pads out and wedge something between the pistons and push them back.
Choice is your's mate, but you aint gonna do it any other way.
Take a flat head screw driver with a verry large head, or any kind of piece of anything (plastic, metal, w/e) that has a wedge shape, then put it between the pads, squeeze the lever hard onto it then when you'll release the lever, the pads will be further appart. Then you'll be able tu put your wedge further into the caliper and ultimitaly having your pads far enough from one another to be able to fit a disk in. Don't make the pistons go in too much, you're going to have the problem of having pads too far from the disk...
Just make sure your wedge is clean and take your time and don't force things...
Good luck :)
Good luck :)
nope it wont becuase disk pads arent a soft compund like maggie pads, like inur said just make sure theres no grease on your screw driver
That's not true. Sure, they aren't as soft as Maggie pads - but it's very easy to take chunks out. And as someone mentioned early - contaminate them.
I'd take the pads out first, or push on something that isn't the pad - like the pad backing.
Also not true. Push them in all the way, evenly. And then when you pull the lever, it will automatically adjust both pads appropriately depending on the position of your pads.
I just remove the pads, lob an allen key through the caliper and pull both the pistons back as far as far as they'll go, then smash the pads back in, bosh wheel in, pump a bit and I'm off. That way, the pistons will reset totally back to where they were before I funked up.
