Flubber Posted July 18, 2007 Report Share Posted July 18, 2007 here's my problem, i cant get my eno off the rear hub. i want to take it off to put on me cranks instead. ive tried everything i can think of, got the tool and been riving at it all day but it just wont budge, any one got any ideas at all??cheers, Flubber:D Quote Link to comment Share on other sites More sharing options...
Grant H Posted July 18, 2007 Report Share Posted July 18, 2007 Lube Quote Link to comment Share on other sites More sharing options...
Synergy Posted July 18, 2007 Report Share Posted July 18, 2007 also you will probable need levrage ifyou have the tool you need something long (no dirty comments lol) something long just ot give it the extra push. Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted July 18, 2007 Report Share Posted July 18, 2007 yep nothing wrong with abit of leverage you can really pull on it hard Quote Link to comment Share on other sites More sharing options...
scott_ftw Posted July 18, 2007 Report Share Posted July 18, 2007 take it to a bikeshop to get it done properly ..........dont risk breaking it Quote Link to comment Share on other sites More sharing options...
Onza-Trials Posted July 19, 2007 Report Share Posted July 19, 2007 use a nice big hammer, always does the job for me. or is that juts why my bike brakes all the time Quote Link to comment Share on other sites More sharing options...
N Roach Posted July 19, 2007 Report Share Posted July 19, 2007 (edited) Try, Putting the tool in a strong and sturdy vice.Get an old frame with no headset, using spacers and bolts attach the tool through the headtube and tighten till the tool does'nt move. This way you will have a very good leverage system. Few drips of oil into the threads, then match the tool with the freewheel, and twist as hard as u can, maybe get a mate to help.(P.S. This is how my local bike shop does it, quite hard to explain!)cheersnafan Edited July 19, 2007 by chocolate_bikes Quote Link to comment Share on other sites More sharing options...
JT! Posted July 19, 2007 Report Share Posted July 19, 2007 You have to bolt the tool onto the freewheel to start with. you should be able to do this using the wheel bolts and a big washer. Once that's on nice and tight, you need a good long spanner. Longer the better. Hold the wheel and use your foot to push down on the spanner. If that dosn't work, kick the shit out of the spanner, or hit it with a mallet. Quote Link to comment Share on other sites More sharing options...
adam le chem Posted July 23, 2007 Report Share Posted July 23, 2007 Get some major leverage on it also make sure the tools is secure Quote Link to comment Share on other sites More sharing options...
Sam O Posted July 24, 2007 Report Share Posted July 24, 2007 Put the tool on the freewheel and add on to it some major leverage, that should do the trick. You probably won't want to here it but I couldn't get mine off at all no matter what I tried so it had to be angle grinded to pieces to remove it. Quote Link to comment Share on other sites More sharing options...
pengsmelly Posted July 24, 2007 Report Share Posted July 24, 2007 well clamp the tool down on the freewheel, (i use an old srew on axel) put it in a vice. this should help the tool not to move out of place. then just pull like hell!!! should come right off. matt Quote Link to comment Share on other sites More sharing options...
