Wheel Rubs When I Pedal Hard
King C
Ok I've recently just got a new frame and rebuilt my rear wheel but now whenever I pedal hard-ish the wheel rubs against the pads. Im gunna try and re-tension the wheel to see if it stops as thats my main assumption to why its doing this.
My second guess would be a snapped axel but I really doubt that as I really not a harsh rider.
It wont be cones as its a Pro 2 (06) and Im still looking for any signs of cracks in the hub shell but I cant see any.
If it doesnt work have you guys got any ideas to what it may be?
Im fairly busy so I wont be able to try your suggestions straight away but thanks in advanced.
King
Well the frame is an Ashton, the rim's an 07 Echo and Ive had to grind alot off my rock pads as it is. It also means I'll have to give the maggie a new bleed cos theres air in my system. Oh well if it means no more rubbing then so be it.
Edited by kcchan
Slight thread hijack... if you power down with your right foot and the pads rub/honk, what pad is rubbing, left or right? Thought it was left, then the right... sick of adjusting the pads will little joy, so which side you y`all think it is?
I'd just like to know to be sure!
im pretty sure it would be the right pad rubbing
This was happening to me a bit today. Try tightening the axle/cones on your hub and that should cure it. I had to tighten my cone on my king tonight, I had to tighten it 4 turns to get it snug. No more wobble though and the hub sounds louder?
Inur is correct, it would pull to the left if you looking forwards on the bike (Disc side to you loosers) but if you have a bent axle and take wheel out and replace it with it twisted in a different place then it would put the wheel squuuueeiff. Meh I dunno, try a rebleed and moving pads abit.
Can somebody explain why the wheel always twists to the right?
Surely if you apply power, the chain pulls the right part of the hub towards the bb, meaning the wheel should flex to the left?
Can't work it out in my head why, but it does pull to the right - try it and see.
i had this a while ago on my old wheel. i tried lots of stuff and none of it worked but the i found out my bolt on the chain side was loose so i did it up mega tight and then i was absolutley fine. try tightening the bolts on the chain side on the frame.
Callum
Could it be that when you put the power down the frame will flex around the bb twiating the frame towards the wheel, but if thats the case it should change which side it rubs depending on which you have as your chocolate foot.
maybe something to do with the torque tightening the spokes on the drive side of the hub more/first, pulling the rim to the right? would of thought that this is similar to the reason why you cant run radial on the disk side, but you can on the non-disc side of the hub.
