Magura Louise Setup?
thornabytrials.co.uk
mines driving me instaine, i set it all up using them washers provided to get the disk sitting perfectly between the 2 pads, all was good for around 10 min of riding then there was a costant horrible noise (kinnda like a rim with tar on and brakes rubbing) and the wheel quite stiff to move, so again i set it back up and perfect... for another 10 min, so last nite when i came home i took a while lining it back up and gettin it working, today went out, 15 min it was spot on, then again rubbing making a very annoying loud constant noise! so yet again i adjusted it, and same story... ive not gave in and called it a day. any one got any ideas how to set the stupid thing up? its very annoying, ive got a feeling its something to do with the automatic pad ware adjustment!
Make sure your wheel is in the fork dropout properly?? Put the bike upside down and lean on the wheel while you tighten it up, then set up the disk. I have this roblem everytime i remove my front wheel.
