0489trials Posted July 14, 2007 Report Share Posted July 14, 2007 Hey everyone, Just wondering how many people use tar on rims and how many don't, is it actually anygood? or are better brakes the way forward Ta ollie Quote Link to comment Share on other sites More sharing options...
clarkytrials Posted July 14, 2007 Report Share Posted July 14, 2007 Hey everyone, Just wondering how many people use tar on rims and how many don't, is it actually anygood? or are better brakes the way forward Ta olliewell personal I like s**t brakes or some times no brakes at all on a more positive note it depends what pads you have I mean with zoo! pads tar is ace but on some others it is bestto grind Quote Link to comment Share on other sites More sharing options...
jsychem Posted July 14, 2007 Report Share Posted July 14, 2007 I think tars great, in the dry it always works well with the right amount and helps the pads to last longer. With tar i don't think that a grind is as necessary and this will also prolong your pad life. Quote Link to comment Share on other sites More sharing options...
jandamna Posted July 14, 2007 Report Share Posted July 14, 2007 Hey everyone, Just wondering how many people use tar on rims and how many don't, is it actually anygood? or are better brakes the way forward Ta olliewell ive only been trial'zing for a couple of weeks now, but a few weeks back i tryed some tar, it really worked well for a while but then it started to stop working as much, and then when it rained it left a black substance on my rim which means i had to clean it all off with white spirit, which was a bum!! lol Quote Link to comment Share on other sites More sharing options...
Matt Breeze Posted July 14, 2007 Report Share Posted July 14, 2007 Tar works well in the dry, but as the other guy said once wet it can make you brake really pants.I used to run tar all the time with zoo! pads and it worked well but after a while i had to suffer with cleaning it all off again. If you want to run tar i think its good if you keep on using it but when you stop you will have to clean your rim well and your brake will feel awful, it took a few days of riding and cleaning to get my rim back to normal... but then i ground it and even though it is bad for your rim , my brake is amazing! Matt Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted July 14, 2007 Report Share Posted July 14, 2007 tar is always good sometimes but if u put too much on can make your brake pads stick and not come off just for that split second you want to do a kick with the pedal and it launches your weight towards and sometimes over the bars,lol, not good, i use a grind it is easy to do works really well with rock pads, and a light grind with some monty pads which is what i use right at the moment Quote Link to comment Share on other sites More sharing options...
EssexGalTay Posted July 14, 2007 Report Share Posted July 14, 2007 i use tar on my echo and its great! it works really well, a few piees of advice; 1. do NOT!! use in rain 2. do NOT!! use too much, can become sticky and screw with your break pads! 3. very noisy! Tay.. x Quote Link to comment Share on other sites More sharing options...
thornabytrials.co.uk Posted July 14, 2007 Report Share Posted July 14, 2007 used to use tar 2 years or so agonow im running onza citrus pads on a smooth rim, excellent imo Quote Link to comment Share on other sites More sharing options...
Trix Posted July 14, 2007 Report Share Posted July 14, 2007 I use tar, it makes standard brakes work so much better, I've only used standard maggie pads though, but works a treat, doesn't work in the wet. Quote Link to comment Share on other sites More sharing options...
JoeEden Posted July 15, 2007 Report Share Posted July 15, 2007 Hey everyone, Just wondering how many people use tar on rims and how many don't, is it actually anygood? or are better brakes the way forward Ta ollieit depends what pads you have u have normal magura pads and they work well without tar but even better with tar but the opiniun will vary beetween other people and different pads. Quote Link to comment Share on other sites More sharing options...
mod_biker_barney Posted July 19, 2007 Report Share Posted July 19, 2007 zoo! pads tar is aceTrue, i run this and my brake hasn't slipped yet...Touch wood.. Quote Link to comment Share on other sites More sharing options...
tom jersey Posted July 19, 2007 Report Share Posted July 19, 2007 I think tars great, in the dry it always works well with the right amount and helps the pads to last longer. With tar i don't think that a grind is as necessary and this will also prolong your pad life.what chem said, Tar *** in my eyes! Quote Link to comment Share on other sites More sharing options...
onzaboy89 Posted July 19, 2007 Report Share Posted July 19, 2007 I use tar and its great but recently due to the rain it has become ground into the rim. What is the best way to remove this? Above someone suggested white spirit but is there any other way? Quote Link to comment Share on other sites More sharing options...
willy wonka Posted July 19, 2007 Report Share Posted July 19, 2007 I use tar and its great but recently due to the rain it has become ground into the rim. What is the best way to remove this? Above someone suggested white spirit but is there any other way?white spirit is the best way, doesnt contaminate your pads or anythingjust takes it off straight away Quote Link to comment Share on other sites More sharing options...
Sam O Posted July 19, 2007 Report Share Posted July 19, 2007 Tar is always a good way to improve your braking power. I don't generally use it but every now and again when i don't want my brake to slip at all i slap some on. Don't put too much on though as your pads will stick to it and i have found that on a hot day it starts to melt and your pads just stick constantly! Quote Link to comment Share on other sites More sharing options...
jambo Posted July 19, 2007 Report Share Posted July 19, 2007 Its all about the tar and zoo pads for the win, what a combo, just a wee bit though!Where can i get tar my mate gave me some and its vanished of the face of the earth? Quote Link to comment Share on other sites More sharing options...
JaMmY Posted July 19, 2007 Report Share Posted July 19, 2007 Tar Does Help!!!! But recks Rim A Bit!! Quote Link to comment Share on other sites More sharing options...
CrOcKeR Posted July 19, 2007 Report Share Posted July 19, 2007 TAR *** but to a certain extent less is more. just dont use in wet and i love the sound its unreal how loud it is. Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted July 19, 2007 Report Share Posted July 19, 2007 Tar Does Help!!!! But recks Rim A Bit!!How does it wreck the rim?, you can easily remove it with petrol, surely a grind does more damage?I liked tar in the time I used it most, its good because if you are doing a move where your brake is a very vital part of the move (drop gaps for example), you can stick an excess amount on and then this will make it stick intentionally, it is also good as you can vary amount so you can have a brake that you can feather a bit. Quote Link to comment Share on other sites More sharing options...
Sucram Posted July 19, 2007 Report Share Posted July 19, 2007 I have a grind on the back, a few little smudges of tar, zoo pads = mint..but not in the rain. Quote Link to comment Share on other sites More sharing options...
Radek Posted July 20, 2007 Report Share Posted July 20, 2007 I used to have magura pads, and in my opinion its s**t cos its too hard and therefore they dont adhere well.I used tar but since i run zoo pads(softer-better), i dont need tar and with brake booster it brakes quite well. Quote Link to comment Share on other sites More sharing options...
N22CK_C Posted July 20, 2007 Report Share Posted July 20, 2007 If you are wee bit deaf then tar rocks other than that wee bit to loud for my liking. Quote Link to comment Share on other sites More sharing options...
