Snail Cams Slipping!
jsychem
nar i dont think there is mate. i had exactly the same problem then got some chain tugs and havent had the problem since.
get some chain tugs or them snail cams with the grooves in are meant to be quite good.
Flubber:D
Flubber:D
Ermm, thats not true, either set them up properly, or get some cams with the notches in.
You could get chain tugs but from my expirence they always bend ^_^ i was actually thinking of making the switch to snail cams. They seem so much easier to set up you wheel and brake. If you get the one's with the little grooves in they should work fine in theory? anyone else had this problem with snail cams?
Regards Matt
Edited by Matt Breeze
