trials-lover-josh Posted July 13, 2007 Report Share Posted July 13, 2007 There are two good ways i found worked for me and my friends.1.First find a small wall,curb or ledge about 2 and a half ft high.Then put your front wheel on the wall ect. and rock slowly and get your balance right.Next come off the ledge and move your legs up and down in a hoping motion.In the mean timekeep your back stright and your arms fairly stright.And lightly be pulling up on ur bars to increase hight.2.First roll about walking pace foward.Then endo up about a foot and a half then comedown and spring up onto your rear wheel.This way is harder as you need more balance to get into your hops.Once up on you rear wheel do the same as the first step by moving in a hop motion.Use the same technique to side hop but you lean to the side you are goin to as you hop up.Also u can swing your back or front around in the air to make it niceror to get closer in to ther place your landing. Quote Link to comment Share on other sites More sharing options...
ilikeriding Posted July 13, 2007 Report Share Posted July 13, 2007 (edited) I don't get that and I can sidehopI always preffered just getting on the back wheel then hopping sideways up the wall/ 2.5ft cerb...., then leaning forwards or backwards to go to front or back wheel . Edited July 13, 2007 by afroman Quote Link to comment Share on other sites More sharing options...
Muel Posted July 13, 2007 Report Share Posted July 13, 2007 I don't get that and I can sidehopI always preffered just getting on the back wheel then hopping sideways up the wall/ 2.5ft cerb...., then leaning forwards or backwards to go to front or back wheel .Yeh, that.You should never have to "endo" to get onto your back wheel, I can go from standing still up onto my back wheel and my back wheel has only moved foward about 1.5ft. Quote Link to comment Share on other sites More sharing options...
willy wonka Posted July 13, 2007 Report Share Posted July 13, 2007 Straight arms when bouncing on the back wheel generally isn't the best position to have.I never like to have my legs/arms straight because it doesn't seem as relaxed, it also makes it feel hard to control the bike.When side-hopping you need to kick at the pedals, otherwise your going to end up going backwards too.Ok, fair enough this is telling people a way to get onto the back wheel but maybe telling them a better position would be more helpfull? Quote Link to comment Share on other sites More sharing options...
trials-lover-josh Posted July 13, 2007 Author Report Share Posted July 13, 2007 Its just the way i learnt guys. Quote Link to comment Share on other sites More sharing options...
JaMmY Posted July 13, 2007 Report Share Posted July 13, 2007 josh you cant even side hop iv seen you every time you have came into liskeard!!!!!! Quote Link to comment Share on other sites More sharing options...
Trix Posted July 13, 2007 Report Share Posted July 13, 2007 To make it easier why not get a video with a step to step guide because I didnt get any of that. Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted July 13, 2007 Report Share Posted July 13, 2007 There are two good ways i found worked for me and my friends.1.First find a small wall,curb or ledge about 2 and a half ft high.Then put your front wheel on the wall ect. and rock slowly and get your balance right.Next come off the ledge and move your legs up and down in a hoping motion.In the mean timekeep your back stright and your arms fairly stright.And lightly be pulling up on ur bars to increase hight.2.First roll about walking pace foward.Then endo up about a foot and a half then comedown and spring up onto your rear wheel.This way is harder as you need more balance to get into your hops.Once up on you rear wheel do the same as the first step by moving in a hop motion.Use the same technique to side hop but you lean to the side you are goin to as you hop up.Also u can swing your back or front around in the air to make it niceror to get closer in to ther place your landing.aload of mumbo jumbo IMO, sorry Quote Link to comment Share on other sites More sharing options...
