Matthew_Gibson Posted July 12, 2007 Report Share Posted July 12, 2007 Right I no this has been posted a million times but no real answer. Okay, I ground the rim on my Mod. Ronnie rim if that make a difference. I set a new pair of heatsink "blueburry" pads. They seemed like a good pad, span the wheel and they made a LOUD honk. Went for a ride, and they had loads of bite, but lacked hold, They slipped like a bitch, I dont really know whats wrong, the grind is light - medium. I tryed some Koxx greens, and they were the same, but silent. Anyone know whats wrong?Cheers! Quote Link to comment Share on other sites More sharing options...
Ryan Blackwell Posted July 12, 2007 Report Share Posted July 12, 2007 I dont no if this is any help but what way are you grinding it ive herd its best to go anti-clockwise but not really 100% on weather its true mate.Or prehaps you may need to give them time to bed in. Quote Link to comment Share on other sites More sharing options...
Muel Posted July 12, 2007 Report Share Posted July 12, 2007 Right I no this has been posted a million times but no real answer. Okay, I ground the rim on my Mod. Ronnie rim if that make a difference. I set a new pair of heatsink "blueburry" pads. They seemed like a good pad, span the wheel and they made a LOUD honk. Went for a ride, and they had loads of bite, but lacked hold, They slipped like a bitch, I dont really know whats wrong, the grind is light - medium. I tryed some Koxx greens, and they were the same, but silent. Anyone know whats wrong?Cheers!Must be your grind, if its fresh and the pads are clean and hitting the rim straight then I can't think of anything else.Try a deeper, harsher grind, I did and it worked for me.It may be that your pads aren't hitting the rim exactly square so they might need to get worn in, but this has only ever happened to me with old pads that have worn funny...I would grind it again and make it well harsh. Quote Link to comment Share on other sites More sharing options...
Simpson Posted July 12, 2007 Report Share Posted July 12, 2007 Bite and not hold can be a few things- lack of booster? frame flexing when you want it not to- Bolts done up well tight to stop them flexing out- Not bedded in? on a feash grinds pads can take upto like 2-3 hours to bedd in- dust on the grim, from grinding? wash it down with water- shit grind? do it harder next time- Wheel not in propperly and "poppig"- Just the pads dirty? file off the top layer of the pad and make em square- rim contaminated? used tyre cleaner or lubed the chain near you rim?Kinda hard for an open question, and yes i am bored lol Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted July 12, 2007 Author Report Share Posted July 12, 2007 Bite and not hold can be a few things- lack of booster? frame flexing when you want it not to - a lot booster needed- Bolts done up well tight to stop them flexing out - yea- Not bedded in? on a feash grinds pads can take upto like 2-3 hours to bedd in- dust on the grim, from grinding? wash it down with water - YES COST ME 89p- shit grind? do it harder next time - most likely - Wheel not in propperly and "poppig"- Just the pads dirty? file off the top layer of the pad and make em square- rim contaminated? used tyre cleaner or lubed the chain near you rim?Kinda hard for an open question, and yes i am bored lol Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted July 12, 2007 Report Share Posted July 12, 2007 kust curious,but are you using cheap grinding discs?i had the same problem as you have and i changed the grinding disc for a better quality one and the grind work better now Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted July 12, 2007 Report Share Posted July 12, 2007 its becuase your frames flexy as f**k get a booster on Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted July 12, 2007 Author Report Share Posted July 12, 2007 Ill go and wack M adamant booster on see it fits! MITE not though! Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted July 12, 2007 Author Report Share Posted July 12, 2007 Ill go and wack M adamant booster on see it fits! MITE not though!Tryed that just before. It helped a bit, I'll put a harsher grind on tomora. I think it would help if I got the washers, there a bit taty! Quote Link to comment Share on other sites More sharing options...
fyfey Posted July 12, 2007 Report Share Posted July 12, 2007 kust curious,but are you using cheap grinding discs?i had the same problem as you have and i changed the grinding disc for a better quality one and the grind work better now yeah get a cutting disc!! 3mm much better.plus the set up of the pads.good luck Quote Link to comment Share on other sites More sharing options...
