grantallsop Posted July 9, 2007 Report Share Posted July 9, 2007 I have a stock rear wheel, its an echo rim. Which hole size would fit that rim because i want to get the monty 219 rear hub (116mm) but it only comes in 32h drillings. Would this fit a 26" echo rim?ThanksGrant Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted July 9, 2007 Report Share Posted July 9, 2007 (edited) yes, they both have 32 holes, ask tarty for spoke lengths as its different to most wheels. arent monty hubs thinner than usual hubs to fit their frames specifically? Edited July 9, 2007 by ash-kennard Quote Link to comment Share on other sites More sharing options...
gianttrials Posted July 9, 2007 Report Share Posted July 9, 2007 I have a stock rear wheel, its an echo rim. Which hole size would fit that rim because i want to get the monty 219 rear hub (116mm) but it only comes in 32h drillings. Would this fit a 26" echo rim?ThanksGrant count the holes in the rim (i believe they're 32 hole) if it is, then in theory you should be able to get it laced up. i guess this is for a mod stock then??? Quote Link to comment Share on other sites More sharing options...
grantallsop Posted July 9, 2007 Author Report Share Posted July 9, 2007 count the holes in the rim (i believe they're 32 hole) if it is, then in theory you should be able to get it laced up. i guess this is for a mod stock then???Yer its not acually for me, it for my mate who isn't a member but i will tell him. Cheers Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted July 9, 2007 Report Share Posted July 9, 2007 echo rims are only made in 32hole... Quote Link to comment Share on other sites More sharing options...
