Metal Posted July 13, 2007 Report Share Posted July 13, 2007 (edited) Can Echo brakes be bled just as easy with water? Will it mess things up because of the aluminum bits?LOLi have not tryed them yet but wont till i get to no them because i am so bad at doin things on bikes so the first time will get one of my mates to do it in front of me and then learn from there.My maggie is a water bleed jamie, so you have used water. Also robs is an oil bleed so uv used oil to. Edited July 13, 2007 by Metal Quote Link to comment Share on other sites More sharing options...
jsychem Posted July 13, 2007 Report Share Posted July 13, 2007 i think there great. Quick and simple to do once you know how, and aslong as you undo the tpa, they'll last a while. Quote Link to comment Share on other sites More sharing options...
Rubb3r Chicken Posted July 13, 2007 Report Share Posted July 13, 2007 I wouldnt ever do it. I havnt read into it much or anything, i just wouldnt. Quote Link to comment Share on other sites More sharing options...
pre67 Posted July 13, 2007 Report Share Posted July 13, 2007 ok... that was easy to read...so when you use water instead of oil, i'm guessing the leaver feels a lot lighter to pull in as well? my maggie does feel a bit sluggish.yer soz about selling never been to good at it lol yer gust bleed it with water it will be fine cuz ate your magy sounds like my old 1 with i bleed it with water and i good naw gust do it i wont f**k it up and if it dus i will be very suprizd Quote Link to comment Share on other sites More sharing options...
The Duck Posted July 13, 2007 Report Share Posted July 13, 2007 I've had a water bleed in my maggy for 2 years and I've never had a problem. One of the fittings came loose on a ride the other day so i bled it with ribena. No problems at all. Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted August 1, 2007 Report Share Posted August 1, 2007 I prefur a water bleed personally like so many others, yes anti freeze is a must if you are getting into the winter months,However there is the stigma that water bleeds ruin seals after a long period of time in some cases this is true but others it isnt, aslong as you maintain your brakes enough then there should be no problems,If you are thinking of running a water bleed with braided hosing then definalty go for the hope hs33 braided hose kit because it has a larger diameter inside compared to the magura braided hose kit, and this larger diameter allows for a water bleed to function better and is more responsive to the rider.Griff.how about goodridge hose?are they ok with water bleeds?also .... can anyone direct me to a shop where i can get 2 m6 fitting for braided hoses?steve Quote Link to comment Share on other sites More sharing options...
chris13 Posted August 1, 2007 Report Share Posted August 1, 2007 just done my water bleed this afternoon, all i can say is WOW!!! Quote Link to comment Share on other sites More sharing options...
Boswell Posted August 1, 2007 Report Share Posted August 1, 2007 Ive been running water for about a year. much better feel, no leaks so far and its impossible to get air in the system if you bleed it in your sink.or bath. Quote Link to comment Share on other sites More sharing options...
