Big Computer Problem, Boot Disk Failure
David
Ok, this is really starting to annoy me now...Yesterday my pc started to behave very odly out of the blue, I kept getting the blue screen of death and stop errors (Unkown hard error) I began to run scandisk which took quite some time but did finally complete. I thought this had cured it until I got the stop error again. I restarted the pc and now I am getting a boot disk failure! The HD (Sata) is not being detected in the bios (I have checked the connection and even plugged it into a different sata socket) I can hear the harddrive trying to spin (Its not making the deadly clicking noise) I am assuming it could be a corrupt MBR? Problem is I cant fix anything as the harddrive isnt detected at all! Any ideas? Ive thought about putting an old IDE Hd with windows on and seeing if somehow I can access the sata hd from within windows although I think this is unlikely if its not detected in the Bios.
Any ideas!?
Thanks,
Dave
I had a very similar problem a couple of years ago. It suddenly started running very slowly, at that time i was copying data between two disks and it just took ages. Ran scandisk which also took ages to complete and after I restarted the PC, the HDD was no longer there. Turned out that the HDD died due to a mechanical error. I'm no expert, but if that's the case and you want to retrieve data from your harddisk, DON'T use it and take it straight to a data lab.
I put a broken HD in the freezer once, it worked after (for 5 mins) :D I dunno why??
The parts get closer together and work for a bit, if you have just a few files you really really need on a dead HD, you can put it in the freezer, plug it back in and hopefully have enough time before it defreezes to transfer your files.
Yeah ive done this before with ipods, the arm gets stuck in place. Its not as usual for it to happen on a big hardrive though, often happens in 2.5" laptop drives and as I said Ipods. I think it may be because the the MBR is somehow corrupted and the drive is trying to constantly read it but failing.
