Will The Rim Fit?
trialschallenger
if it doesnt, invest in some tensile brake mounts as they will move the calipers and let you set the brake up well
I doubt that will be the problem i should think he is meaning will there be a big enough space for the rim and tyre in the frame itself between chainstays??
because that would have envolved getting the wheel re-built(wich is the problem i had on my bike)
and if then it didnt fit it meens it need re-building again
I know this is going to seem really radical, but... take his wheel out.... then slide just your rim in. If you worried about tyre clearance, put a tyre on the rim and slide that in too.
Phew, that was hard to explain, gonna need to lie down now :-
