Tar And Grinding
Jimmy_E
my grinds usually last like 2 months before i grind it again.
but i do like them sharp, so i could leave that grind on for longer...
i used to use tar, but its nothing like a grind. it doesn't work in the wet too
i just found out that no grind is how i like it! maybe other people dont but i do i use echo reds on smooth rim with tar its got loads of bite and hold not so good in the wet but i dont ride in the wet! plaz work good on smooth aswell. but some people like grinds and some people dont so its up to you.
Edited by tom/j
you put a new one on like every week, youre always saying how its shit
i run both setups.......for hot weather i run plazz pads on smoothe rim ....but most of the time i run a light sharp grind on plazzy pads with works verry well and i re grind my rim every 2/3 months
hope this helps............
p.s......when i lived in spain i ran only tar.....works a treat
hi could sombody explain what grind and tar is im guesing tar is tar of the roads? sorry for being a noob but im intrested lol
tar off the roads doesnt do much good, roofing tar is what you want (Y)
tar basically makes the pads stick better to the rim, increasing friction and braking power.
a grind is where you use a angle grind and skim the grinding disc along the rim.
this increases the surface area that the pads bite into making the brake more powerfull.
personaly i love tar, nice bite and reli nice loud sound. get the heads turnt :)
but the thing is it doesnt work in the wet :( ive just got a grind on rear and its amazing si little hasstle. i would advise tar on the front with smooth rims nice bite and strong hold especially with standard pads :)
cheers rob
p.s. i dont care wat other people think
take a look at the rides below :)
