Disc Rotors
T.McMillan
I was just wondering about buying a new disc rotor i run a 180mm hope trial disc 06(with the black caliper), I have found loads of different disc rotors on chain reactions, just wanted some help.
1. Are most disc rotors the same thickness to fit in the caliper i.e. will an avid, formula, hayes etc, disc fit into the hope caliper?
2. I have seen the hope saw rotor and they do it in 183mm size will this fit into the 180mm caliper or will it be a fraction too big?
3. I also saw Rich's Leeson disc for sale i do like, would of that been able to fit?(somehow i dont think it would)
Also found this i know its abit of a random product to sell but i think its a good idea :Plol chainreactionscycles
Cheers
Tom
P.S. Thanks for your help in advance (Y)
Cheers
Tom
1. Generally yes..i've used an avid rotor, a hope rotor, and a magura rotor on my old maggy louise.
2. It should fit just perfect matey :)
3. not a clue...not seen his rotor.
I think the 183 rotor will be too big for a 180 caliper won't it? Avids you can usually space out, but it's not the same with Hopes.
If you buy the rotor from Hope direct, I believe they can do any size.
