Will Fairburn Posted June 28, 2007 Report Share Posted June 28, 2007 Evening all,After about a week of trying learn Huck's, I am getting no way near close, so could anyone go through how to Huck this is on a vertical wall.1) Do land both wheels at the same time, or rear first?2) What brakes do you have on when hitting the wall?3) What brake are on/off when coming off the wall and going to the top?4) How fast do you need to hit the wall?Cheers, WillP:s, I have used the search! Quote Link to comment Share on other sites More sharing options...
modman Posted June 28, 2007 Report Share Posted June 28, 2007 Evening all,After about a week of trying learn Huck's, I am getting no way near close, so could anyone go through how to Huck this is on a vertical wall.1) Do land both wheels at the same time, or rear first?2) What brakes do you have on when hitting the wall?3) What brake are on/off when coming off the wall and going to the top?4) How fast do you need to hit the wall?Cheers, WillP:s, I have used the search!huck?? i always thought that josh bender and all his lot used to do off huge 50+foot drop offs? Quote Link to comment Share on other sites More sharing options...
Will Fairburn Posted June 28, 2007 Author Report Share Posted June 28, 2007 last time in a topic i put something about hucks i put hooks n most people said it was ''huck'' Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted June 28, 2007 Report Share Posted June 28, 2007 (edited) Right. Hit the wall at quite abit of speed.Once you hit the wall keep both your brakes locked.Then just push forward, bring your back end up and push on your front wheel.Your up Danny. Edited June 28, 2007 by Danny Kearns Quote Link to comment Share on other sites More sharing options...
eskimo Posted June 29, 2007 Report Share Posted June 29, 2007 I found speed helps. I guess once you got the technique they are rather easy. Watching Ben Rowlands do them with slippy brakes was mental. Anyhow the furthest i got was to bash guard. Also trying it on a higher wall than you can already get up helps. Try not to land 'down' onto the wall. Quote Link to comment Share on other sites More sharing options...
ilikeriding Posted June 29, 2007 Report Share Posted June 29, 2007 (edited) Right. Hit the wall at quite abit of speed.Once you hit the wall keep both your brakes locked.Then just push forward, bring your back end up and push on your front wheel.Your up Danny.You land both wheels at the same timeI do them without the back brake on, until I reach the top.remember when your bunnyhopping into the wall, land with your weight as far over the front as it will go. Edited June 29, 2007 by afroman Quote Link to comment Share on other sites More sharing options...
