Hs33 Hellppp Bleeed
shansen
Right Ok, i broke the cross over cable on my rear maggie, ive paid 15 quid for a bleed at the shop countless times so i fort id give it a bash my self...... i replaced the cross over cable with my friends one.... i decided to try and bleed it in the bath.....
so...
First i undid the bolt next to the cable on the leaver... like the hole thing (underwater)
Then i undid the bolt on this pic (underwater)
then i just pumped the leaver like crazzy and did up the bolts again (underwater)
then i took it out and expected it to work lol an it didn't :(..... this is my 1st time trying to bleed a break please help it would be nice to be able to ride 2 moz (Y)
Thanks Seb
Allow the air to come out of the top using a siringe can help do this there only a fiver or so
remove all TPA and stoff
Cover 1 of the holes why pumping the other?
i dunno i can't bleed brakes for shit, just get a dengura :P (jokes)
use a seringe and half a crosser pipe with a barb in one end.
screw this barb into the hole next to the hose on the lever body and keep pumping water through the brake with the seringe but remember to pump the brake at the same time, and also do it all under water.
doing this should make your brake work mint (Y)
louis ...
Edited by Louis p
louis ...
ok guys ill give it a try (Y)
Get the whole lot as you had it before, but have your finger close to the hole in the slave cylinder (pad movey bit). When you press the lever in, let air come out, before you let the lever go put your finger over the hole, then let the lever out. Repeat till air stops coming out.
do you have any other substances come out of the slave cylender when you pump the lever?
when i first tried bleeding my brake in the bath loads of white crap came out want air, just a horrible flem like substance! Not to sure what it was but anyway, i let all of the air out and i was pumping the lever for a fair time and this stuf kept coming so i thought it was usual but i then found i had to pump the lot out, even the tiniest of bubbles so just keep pumping that lever and it will all be good!
