Pluc Posted June 26, 2007 Report Share Posted June 26, 2007 Hi,I'm thinking get setup of Echo front screw sprocket and bashring in Adamant CNC cranks.It has some risk of the sprocket to free screw in back tricks?Thanks. Quote Link to comment Share on other sites More sharing options...
Mike W Posted June 26, 2007 Report Share Posted June 26, 2007 Do you mean your going to run a front fixed sprocket with a freehub on the back ?Or do you mean to run fixed sprocket on your cranks and your hub ?if your doing the first one its okaybut i wouldnt do the other or, i doubt you could do alot....mike Quote Link to comment Share on other sites More sharing options...
Boswell Posted June 26, 2007 Report Share Posted June 26, 2007 Look over what you have written it doesn't even make sense. Quote Link to comment Share on other sites More sharing options...
jsychem Posted June 26, 2007 Report Share Posted June 26, 2007 In english please....... Quote Link to comment Share on other sites More sharing options...
dave85 Posted June 27, 2007 Report Share Posted June 27, 2007 Hi,I'm thinking get setup of Echo front screw sprocket and bashring in Adamant CNC cranks.It has some risk of the sprocket to free screw in back tricks?Thanks.No, it shan't unscrew, all the forces through the sprocket wether you are going forwards or backwards act to tighten it.Look over what you have written it doesn't even make sense. I understood it so it can't be that bad.In english please.......Consider the name Everton Ribeiro, not English is it?Now get your head out of your islandic arse and consider that his English is probably considerably better than your Portugese. Quote Link to comment Share on other sites More sharing options...
Joe Sheehan! Posted June 27, 2007 Report Share Posted June 27, 2007 Look over what you have written it doesn't even make sense. Possibly because hes foreign.. Quote Link to comment Share on other sites More sharing options...
