Advantages/disadvantages
grantallsop
I was looking at buying a new 26" frame soon and was wondering what difference it makes if you have a 116mm frame or the 135mm. Anyone know any advantages or disadvantages to these two frames? I only know that you have to have different size hubs in them, but is there anymore?
Cheers
Grant (Y)
Edited by grantallsop
No nasty mech hangers to be bent on a 116mm frame. So that means you can't run gears.
What we doing tomorrow because I am thinking differently because I have some stuff to do and by the time I finish it will be to late so do you want to come to Torquay for a while
Edited by ALEX@BIKETRIALSFUN
Basically dont get a 116mm frame.
unless you have funbolts (something grippy) the dropouts mean that when you kick hard on the pedals the wheel tilts to the drive side and will rub against the frame.
It means the wheel is more awqward to take out due to the snail cams
smaller flanges on the hubs used in 116mm frames weakens the wheelbuild considerably.
the 135 means you need a tensioner, not really much of a problem.
In a nutshell.
But, if you can actually build wheels good, they arent too bad and some good snail cams or some sort of sprung tensioner would be mint.
you mean like beau's wheel building? :P
Edited by Grant H
:S Thats got to be the worst excuse ever :P Mod riders manage fine taking wheels out with snail cams etc.... Don't see how the problem is worse with a stock :S and if you don't like sail cams, use chain tugs
more effort
more effort
what are you on about? more effort, he has a good point the wheel doesnt move if u use chain tugs so whats the problem, some chain tugs are not very good such as my random ones on my mod bike which bent just doein a shift, i think the wheel wasnt very tight but if you get good tugs or snail cams there shouldnt be a problem with horizontal dropouts!
I was about to go off on one before realising someone else had the sense to call him out.
it seems he's repeating himself with the fun bolt shite. I have run 116 hub's for a good while now and have never experianced what he is talking about. I don't use 'fun bolts' I use the standard shitty ones that came on my wheel. When snail cams are used right they wil work just aswell as a dropout bmx style tensioner (better imo as they are smaller= less to break).
but yeh, if you ride stock get 135, if you ride mod get 116, it's pretty simple really why do people feel the need to mix it up??
