Help Help Help
lewis.jackson
The analogue way is to use a micrometer to measure the bolts so that you can order the same size.
Digitally, you could look up on the internet the part the bolt is for, and then either look at the specs or request them from the manufacturer.
What kind of a chart you are envisioning i do not know.
The sort of chart that has a pic with the size under it.
My mate had one off the net and i want one cus he lost it.
So there's a chart in circulation with all the sizes of bolts on. And you have a bolt in your hand. And what you do to find the length is to hold it up to each of the pictures, in turn, until you find one that matches, and then underneath it tells you the size?
Like someone's said, use a ruler my friend.
This website might help. It did me.
Yer thats rite and if i use a ruler how do i know if its a m4 or m5 bolt
So if i just add 1mm then id be rite (5mm bolt + 1mm = m6)
(6mm bolt + 1mm = m7)
I don't know weather that's always the case.
The M number is the original width of the shaft into which the thread was cut. So, the diameter of the shaft at its widest (outside the thread) in milimeters is the M number.
