onzaboy89 Posted June 19, 2007 Report Share Posted June 19, 2007 I currently have a set of 24inch trials forks on my zoot. The only problem is that the head angle is very steep. Is it possible to get a 26inch fork with the brake mounts in the correct position for 24inch wheels for HS33's or will i have to go for a disk brake on the front? Quote Link to comment Share on other sites More sharing options...
dustyw Posted June 19, 2007 Report Share Posted June 19, 2007 you could try and make some new mounts because I dont think there are any 26inch forks with brake monts in the correct place! Then you could weld them on in the right place. this is probably a bit of a mission to do so i wouldnt bother. I would probably just stick with normal 24inch forks or put a disk on the front like you mentioned. Quote Link to comment Share on other sites More sharing options...
